Question about Kenmore Sewing Machines
I need an instruction booklet for sears Kenmore sewing machine monogram set. Do you have one?
Anonymous
SOURCE:
Anonymous
  • 323 Answers
SOURCE: instructions for theading a Sears Kenmore Sewing machine model 158.14000
all machines thread the same. TTN tension,take up, needle.
Beginning with the spool, guide the thread through the thread guides to the tension assembly. Pull the thread through the tension assembly and test it to make sure the tension is working correctly.
(To do this test,adjust your tension setting to normal or medium or 5 or something in the middle. Raise the presser foot and pull the thread through the tension. It should pull easily!! Lower the presser foot and pull the thread. It should pull noticeably harder.) If it passes this test, continue up through the take up lever,then down through the thread guides to the needle. Make sure your needle is fully inserted and turned the correct way.( If you load your bobbin case from the left side,the needle rule is normally FLAT to the RIGHT is RIGHT. There are some exceptions. If you have a newer style drop in bobbin or your bobbin case loads in the front then the rule is FLAT to the BACK.
To wind the bobbin, guide the thread around the thread guide on
the left top of your machine, then to the bobbin winder. Wind the thread around the bobbin several times, place the bobbin on top of the bobbin winder, push it against the wheel and press the foot pedal. It should stop winding when the bobbin is full or you take your foot off the control
Sewman7
Posted on Jun 05, 2008
ken dourof
  • 980 Answers
SOURCE: I need a manual for a Sears Kenmore sewing machine model 148.231
Try www.sewing-machine-manuals.com and click on relics and don't be put off by the word relics
Posted on Oct 24, 2009
Zenqi
Paul Howell
  • 208 Answers
SOURCE: Need manual: Kenmore sewing machine 158.9
Those books are long since out of print. Try contacting sewing machine stores who stock old instruction books. Many shops do this. Or try eBay.
http://shop.ebay.com/i.html?_nkw=instruction+book+kenmore+sewing&_sacat=0&_trksid=p3286.m270.l1313&_odkw=instruction+book+sears+kenmore+sewing&_osacat=0
Posted on Jan 24, 2010
  • 102366 Answers
SOURCE: NEEDED AN OWNERS MANUAL FOR AN OLD SEARS KENMORE
http://www.managemylife.com/mmh/owner_manuals/20746/
KENMORE-Mechanical-Sewing-L0709245
http://www.managemylife.com/mmh/owner_manuals/26810/
KENMORE-Mechanical-Sewing-L0712571
Posted on Apr 28, 2011
SOURCE: I NEED AN INSTRUCTION BOOKLET FOR THE BERNINA 1090
You can possible get the manual for your product here as a pdf file
http://komputerbekas.berita-terbaru.net/bernina/bernina-1090-instruction-manual-sewing-machine-manuals-and-free-.html
Regards
Posted on Sep 27, 2011
How to install a Kenmore monogramer to a Kenmore zig zag machine
You are replacing the presser foot with the monogramer and you will need the very specialized instructions for it's proper use.
Jan 30, 2014 | Sewing Machines
Monogram manual
Is this your machine? 158.1914 http://www.sewingmanuals.com/Sewing_Machine_Manuals/Kenmore.htm
Dec 19, 2013 | Kenmore Sewing Machines
I have a kenmore 385.19106 sewing machine. I am
Go to Sears and talk to their sewing machine dept, I am sure that the salesperson will explain it to you for free. You need to have instruction beyond a book. If, you cannot go to Sears, check with your neighbors, there has to be one that sews or your local high school, Home ec teacher. Good luck
Sep 15, 2010 | Kenmore Sewing Machines
On my Kenmore 15250 sewing machine to wind the bobbin I need to release the clutch by turning clutch knob towards me, so says the instructions booklet. But the clutch knob does not move apart from the...
On my Kenmore I had to pull the knob out to release the clutch, then push it bak in. I don't know if that is the same for you. You can try it, if it doesn;t move, it was worth a try. You could just take to Sears, sewing machine department and ask the salesperson what to do, they should help you for free, our Sears is pretty good about such matters.
Sep 13, 2010 | Kenmore 15208 Mechanical Sewing Machine
Jan 24, 2010 | Sewing Machines
Monogram larger
the two sizes of monograms letters are upper and lower case
Feb 21, 2008 | Kenmore 19606 Computerized Sewing Machine
Sewing Machines Logo
51 people viewed this question
Top Kenmore Sewing Machines Experts
Kelley Buchanan
Kelley Buchanan
Irene Tulloch
Douglas Plant
Douglas Plant
Are you a Kenmore Sewing Machine Expert? Answer questions, earn points and help others
