Question about Panasonic Televison & Video
I HAVE A PANASONIC PLASMA MODEL TH-42PA60L. IT WORKS GREAT WITH CABLE OR DISH BUT HAS NO SETTING/INPUT FOR ANTENNA. ANTENNA AND COAX TESTED GOOD. NEED HELP WITH MENU/SETTINGS TO USE THE ANTENNA.
    Top Expert:
  • Panasonic Master
  • 66,248 Answers
You need to change the input source to air or antenna
Posted on Nov 11, 2019
6ya staff
SOURCE:
dennis bullard
  • 4090 Answers
SOURCE: Panasonic Plasma no sound, can't change channel
Yes the control board would definitely be the offender here. But a word of caution. Oftenj when this board goes 2 other boards are also compromised and not always obvious at the time people think they can just swap the board out.
It went for a reason, not just old age. So it is better and cheaper in the long run to get a professional to check it out.
Also from a safety aspect, this is the High Tension area of the TV. Also be aware that radiation of the X type is in abundance at the rear of the tube. The TV must be grounded when opening ( but my advice is dont!) Let the professional do it
Posted on Sep 18, 2009
Anonymous
SOURCE: Panasonic plasma TV model TH-42PD60U won't turn on
I had this problem in 2007 / 2008 here is what happened to me. Jan 09, 2008 - I also have brought the unit to the authorized Panasonic repair facility and the problem is a failure in the P-board which is the power supply board. The P-board needs to be replaced. The repair will cost $475 plus tax. $250 is for labor. The unit was nop more than two months out of warranty. This does not speak well for Panasonic. I have been researching the problem and it looks like this has happened to many of the Panasonic plasma TVs.
Jun 14, 2008 - As an update to my problem with the failed P board. Contacted Panasonic Service and talked to a customer service representative. I told them how I have purchased many Panasonic products and how unhappy I was with the failure of the product. They proposed paying the labor cost of $250 and I would pay for the part. I just hope it does not happen again.
Posted on Oct 14, 2009
Martin Murray
  • 1623 Answers
SOURCE: Panasonic Plasma Monitor TH-42PWD7B - Convert to TV screen?
hi yvonne not sure if you sorted this but using this lead should get you sorted
http://www.maplin.co.uk/Module.aspx?moduleno=4702
the phono blugs ae used for audio and bnc plugs on the back of your panny are for the video
Posted on Oct 28, 2009
Anonymous
SOURCE: Dish Network HD Monitor HD 40-300
I have a Dish Network HD40-310 Monitor. When you turn power on the green power light comes on, then tv makes funny noise, then goes off again without producing any picture. Any ideas how to fix?
Posted on Jan 01, 2010
BElectric
DILLIGAF
  • 1140 Answers
SOURCE: I am having trouble recieving over the air digital
I believe you have probably selected the wrong TV mode. It seems that you have set the TV to analog mode. It is common for the digital tuning option to be greyed out in analog mode and only becomes available in digital mode. Look for a button on your Sharp remote labelled "DTV" or "DIGITAL" and press this, then open the menu and try the digital setup again. If you don't have one of these buttons, look for a button labelled "INPUT" or "SOURCE" and look for an input or mode called digital or DTV.
I will check on the exact method for your TV and post back with the details shortly.
Regards,
BElectric.
Posted on Feb 10, 2011
Panasoics plasma viera rv will not auto tune telling us to insert aerial already in Model TH-P50X20Z
The manual for this TV can be found here. If you are watching broadcast television, or cable TV service that does NOT require use of a set top "cable box" tuner, you would connect the coax cable from the UHF / VHF antenna or cable into the ANT cable connector on the rear of the TV as shown on page 8 & 9 in the manual.
You would then tell the TV setup to scan for available channels as shown on page 12 of the manual.
If you are using a seperate tuner - like those supplied by Cable TV, Dish, DirectTV, Satellite, etc. you should use (1) the HDMI 1, 2 or 3 inputs (HD) 720P and up; (2) the RGB inputs of AV2 for best picture quality 720P or better (HD), (3 & 4) the AV1 & AV3 (on the side next to HDMI) for 480i and possibly 480P (SD) and finally the ANT connector for 480i. If you have a computer that offers VGA jack to connect to an external monitor, use the PC connector on th erear of the TV to send it HD images.
Page 27 & 28 detail manual channel editing.
Mar 14, 2013 | Panasonic Viera TH-50PX80U Plasma TV
HDMI inputs are not working
As crcelect suggests you can run the TV on RCA. You should also be able to use coax directly from your cable box. If you don't have cable you can use an rf converter to connect coax.
I have exactly the same problem with my Panasonic TH-42PX75U. I've been told that I may need to run a setup on my cable box to fix the problem. If I find a solution I'll provide details in a future post.
Nov 01, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
ftp://ftp.panasonic.com/television/om/th-42px20_en_om.pdf
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Hooking Up Panasonic sc-ht670 home theater to Dish DVR 625 and Panasonic TH-42PHD7UY Plasma TV
You will need to run a set of audio cables from the TV1 output on the rear of the 625 directly to one of the three audio inputs on the surround system. Thanks for using Fix Ya.
May 13, 2009 | DISH Network DVR-625 DTV Receiver /...
Apr 04, 2009 | Panasonic TH-37PE30 37 in. Plasma...
How to hookup vcr to TV to tape from satelitte
have a look at ur install bock it will tell u how to do it...connect antenna to ur vcr then use cable from ur vcr output to ur tv antenna ,,,,,after u have done this read instruction .....to connect ur dvd ....just plug ur cables from ur dvd to the back or ur tv....marked as dvd input....
cheers and good luck......very simple.....
Mar 06, 2009 | Panasonic TH-42PX500U 42 in. Plasma...
Panasonic th-37pwd8uk hook up
Have you tried using the video out and audio out RCA jacks from the directtv receiver and inputting this signal into the composite video and audio inputs on your EDTV?
Jan 27, 2009 | Panasonic TH-37PWD8UK 37 in. EDTV-Ready...
Panasonic plasma TV has a black screen after disconnecting Dish TV
proably not tied in tv nomore dish will take over that prot if u got dish hd u get locakls form dish free in hd dont need attc nomore
Oct 10, 2008 | Panasonic TH-37PD25U/P 37 in. EDTV-Ready...
New TV - no picture at all
Try pressing input on your remote and make sure the source is selected to what you have it plagged in. For example cable box plugged into hdmi1 set input to hdmi 1. Also can you access tv setup at all? If not your tv might be bad to begin with.
Apr 26, 2017 | Panasonic TH-50PHD7UY 50 in. HD-Ready...
Televison & Video Logo
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Demonic-2011
Demonic-2011
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
