SOURCE: Whirlpool Duet washer fills with water by itself
sounds like a faulty water inlet valve, not seating properly after closing the valve.replacing the valve is the only solution to this problem, in the meantime you can turn off your water supply in between doing loads.
not a bad habit to get into!!!!
SOURCE: i have a front loader whirlpool duet #ghw9100lw2
The filter on your pump is probably clogged with lint and stuff. You have to remove the bottom front panel, 3 torx screws underneath. The panel will drop and come off. Drain off the excess water from the drain pipe you see. The white filter cover is right in front. Get yourself a good plastic bag to collect water. Unscrew the filter cover and twist the filter out. Clean out all the stuff and put it back in carefully. Check your pump too, comes after the filter.
SOURCE: I have a whirlpool duet
check this site
http://www.assuredparts.com/WhirlpoolDuetWasherFaultCodes.html
error code page
SOURCE: Duet Sport HT WFW8400TE Washer: Whirlpool Duet Sport HT front loader is stopping b...
First check your washer plug to see if the connections are tightly
screwed. Next check your filter if you haven't for long.
Remove
the 3 screws at the bottom of the front panel under the
washer door. Your filter door will be light brown. If you find a hose
there it is to drain out excess water (water that could not be drained
by your pump) After you hv drained unscrew the cap and
remove all the junk inside. Have a large plastic bag to catch junk and
water. Refit carefully after cleaning out. If not solved, something
shd be blocking your pump, check this out
How abt a nice rating
for the free help? Thnks
SOURCE: Whirlpool front load washer getting an error code of "F6"
f 06 is a in issue with the motor control board, check the wiring harness attached to the board.
