Hi Upul73879, indicates Toshiba TV model, what are you commenting on and what do you want to connect it to, in order to find the best possible solution
I wait your answer
Greetings Franco Dosil
Hola Upul73879, indica modelo del TV Toshiba, que estas comentando y a que quieres conectarlo, para poder encontrar la mejor soluci?n posible
Espero tu respuesta
Saludos Franco Dosil
SOURCE: How do I connect my Laptop computer to my LCD TV?
Every laptop has at least a VGA (computer video connection) and s-video cable port. A VGA cable is preferred if you want to be able to read text on your LCD TV. Check to make sure that your LCD TV has a VGA connector. It's a port that accepts a 15-pin connection so it's pretty easy to spot if it's there. It's just like a computer monitor cable if that helps. Should be able to find it at any local retail store that carries computers. VGA or RGB cable.
