I have seen comments that sometimes I put a lot of info.
When I put a number of link it is because I see something on the link which may be helpful. Some of it can be repetitive but each one may provide some additional info.
https://producthelp.whirlpool.com/Laundry/Washers/Washer_Product_Assistance/What_is_an_F20_or_FH_Error_Code_on_a_Front_Load_Washer
http://forum.partsdr.com/showthread.php?644-Code-HF-on-Whirlpool-Duet-Washer
https://www.youtube.com/watch?v=meGhQ8EiIVI
https://www.youtube.com/watch?v=yqgBD8IAo5s
https://www.justanswer.com/appliance/6mjdo-whirlpool-washer-giving-hf-code-does.html
The link below had problem with hose to pressure switch
https://www.youtube.com/watch?v=uD729VDjKvg
https://www.youtube.com/watch?v=l-iwT9VGXK4
SOURCE: My whrilpool duet washer is
I found that my washer would not drain which is why I was getting the F02 code. I first pulled the strainer to see if it was plugged and it wasn't. I turned the little impeller to the right of the housing and it was free moving but it moved in and out as well as turned. That made me curious. I then to a shop vac and pulled on the drain hose at the wall hook up. It pulled and I could put my hand inside the strainer housing and felt the suction.
This led me to my last tought which was to pull the pump off the strainer housing. It only took three screws and when I pulled it I saw the impeller. When I pulled pack on the impeller it cam right out of the motor and I could see the end of the shaft had sheared and the grinding sound I heard was the shaft ends grinding and it was not able to move any water from the basin.
Im now looking for a new pump cause Im sure its one unit. So far they are over $100 for the complete housing and pump. Im hoping I can just find the pump.
SOURCE: whirlpool duet FH code
its possible you have the correct number, but yes the FH is a "no waterdetected" fault, are you sure you rehooked all wires in the rightt location and in the right position(it possible to put a harnes sin the wrong slot or even upside down, the only 2 CCU's out there for this model and of you had the wrong one you would get wrong cycle selections, not anything to do with the intake waster, i would really recheck your connections
SOURCE: whirlpool washer CCU replacement
Hello, the F-11 means "Serial Communication Error" that is communication between the central control unit (CCU) and the motor control unit(MCU) cannot be sent correctly. Check the following:
1. Check wire connector to the MCU, the motor and the central control unit(CCU).
2. Check the drive system for any worm or failed component.
3. Check MCU.
4. Check CCU
5. Check motor
6. Check wire harness
Thanks
SOURCE: Whirlpool Duet Sport f-01 even after replacing CCU
F01 - There may be an internal problem with the control, attempt a Hard Reset.
Hard Reset - In some cases the control can be non-functioning or may not accept activation from the control panel. To clear and restart the control follow the these steps:
* Unplug or turn the circuit breaker off for 30 seconds.
* Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
* Press the Pause/Cancel/Stop button twice to clear the "PF" in the display.
* Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts.
The F01 generally indicates a failed electronic machine control board.
This error code can sometimes be caused by a glitch or power surge through the electrical lines.
You may be able to clear this code by unplugging the washer for 5 minutes.
If the code returns after plugging the washer back in, then the electronic machine control board will need to be replaced.
The procedure for accessing and replacing this control board is shown in this image...
http://media.fotki.com/1_p,wkwdftgtbkdgfrwxgtqsskgwtqkq,vi/ksrttqdqrxkssrqtgsd/1/1303472/5961857/image12917img-or.jpg
Be sure to unplug the washer before accessing internal components.
When you access the control board, I recommend transferring the wires from the old control board to the new replacement control board one connection at a time.
Once you have all of the wires transferred, remove the old control board and mount the new control board in the washer.
Reassemble and test the washer.
The "F01" error code indicates a communication error between the Central Control Unit (CCU) and the EEPROM onboard the CCU.
The "F01" can also be displayed if the onboard "Pump Driver" fails to activate.
Generally in order to correct this failure will require replacing the CCU.
There is no way to test and verify if the control board has failed.
The technical data sheet basically states to replace the CCU.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
SOURCE: SUD Code appears on Whirlpool
sud means over suds are you useing he soap maybe too much.......
