Question about Watches
I have a wear fit. Used to work great. Now the steps and sleep say data temporarily unavailable? Can I do anything to fix? Love this watch
4 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 26 Answers
SOURCE: larger clasp
Unfortunately, I do not think this is going to be an easy fix. You may want to take it to a local independent watchmaker. Gucci may sell larger clasps but they may be difficult to find even from them directly. I have looked at the watch you have. It it was solid gold a Jeweler could just make it a touch larger.
Looking at the clasps the options i see is
Have the bangle removed and wear it on a leather strap,
Possibly remove the clasp where it says gucci and have the pins laser welded so that the clasp stays in a fixed position similar to a bangle.
mike --consumerwatchguide.com
Posted on Jan 03, 2009
JHUDZEE
SOURCE: everytime i get inline in myyearbook it says Service Temporarily Unavailable
HELP PLS??
The server is temporarily unable to service your request due to maintenance downtime or capacity problems. Please try again later.
Posted on May 27, 2012
nicole kritikos
  • 22 Answers
SOURCE: i cant sign up in badoo it says We're sorry, this page is temporarily unavailable. We're currently working to fix this problem.
try creeating a new account by signing up a few more times or go to a website to get new secure password
Posted on Oct 24, 2012
For about a month, while the watch did keep time, the second hand only moved 4 seconds at a time. In other words, it would no move each second, just in 4 second intervals. Now it is not keeping time,...
Your watch is fitted with EOL (end of life). This does not mean end of watch life, but end of battery life. Replace battery and watch will work as it should. Rate me, please.
Feb 27, 2011 | Omega Seamaster 300M Mid-Sz 2551.80.00...
Can a cloth "sport type" watch band be used on a
mcdevito75 here, As lomg as the watch band, no matter it"s material fits the watch lugs and your wrist, any band can be used. Your answer is yes.
Feb 09, 2011 | Casio Pathfinder AltimeterBarometer...
My watch stops in the night.But works fine when i wear it.any ideas?
Yes, the Movado is a self winder, and it was designed for the sports active wearer, of which the motion of the wearer's arm provides the power to keep the watch wound. Apparently you are not active enough for the watch to be fully wound, so when you take it off, it will use up all of the stored energy in the spring and stop. many self winders will only store enough energy for 8-12 hours of use and will require constant wearing. You could try wearing it to sleep and see if this is enough to keep it wound.
If you feel that this is not the case for your watch, then you may want to have it looked at by a watch maker
Jan 23, 2011 | Movado 800 Performance watch
Garmin FR60 Watch for women. Since changing the battery I have an error message of AH02.300 0000 AID2.200 000. None of the buttons will work
I ran into same issue, would love to know your fix if you have one......I have an email into Garmin for support, because neither of the steps below worked for me.
From what I gathered, you need to try these steps first
a) hold enter and mode simultaneously 4+ seconds to reset the device, or
b) (THIS STEP WILL DELETE YOUR DATA) hold mode, light, and up simultaneously for 4+ seconds.
Jan 08, 2011 | Garmin FR60 Wrist Watch for Women
Have a date just that stops 12 hours after wearing. What is the standard length of time it should run after wearing.
The running ime for a self einding watch (which I presume tha yours is) varies from maker to maker and model to model.
I explored their web site but was unable to find anything useful about running time.
Most other types run for a time in the range 36-72 hours and 12 hours seems rather mean as it does not allow much more than sleeping time before it stops.
I suggest that you approach the supplier and discuss it with them.
Nov 26, 2010 | Rolex Datejust (538) Watch for Women
Evening: I have had my data link for about 3 years. The battery went dead so I went to a watch repair place to have the battery replaced. The watch works great, BUT it doer not beep. All the beeps are...
Same thing happened to me, took watch to watch shop, they changed the battery and the chimes stopped working. Simple fix, the faceplate was put back on wrong. Unscrew the face plate and turn it upside down (or right side up depending on your POV) the circle on the inside of the faceplate will line up with the springs inside the watch and the chimes will start working again. If you have a pair of eyeglasses screwdrivers, like I did, you can do this yourself.
Nov 25, 2010 | Timex Ironman Data Link 5C291 Wrist Watch
I HAVE KC 3500 WATCH.MY BAND IS IN TERRIBLE CONDITION.
You do not need exactly the Kenneth Cole watch band. Measure the distance between watch case lugs - this will be the width of your new band. Go to any jewellers shop you like, ask them to show all watch bands of this size and choose whichever you like. Ask them to fit it as well if you do not fancy to do it yourself.
In case if you have a buckle with KC logo and want to keep it, then take it with you and ask to refit the buckle as well.
Rate me, please.
Mar 12, 2009 | Kenneth Cole RK5034 REACTION
Larger clasp
Jan 02, 2009 | Gucci 1500 YA015512 Watch
"Tissot Touch" Touch screen failure
it all stems from the watch not actually being waterproof it's more water resistant than waterproof. The little indentations on the back that look like they are for a tool to unscrew it are actually holes i guess for the altimeter and meteo so it can sense pressure. Behind the back just behind the holes is a nylon gauze material and underneath this is a sensor slightly recessed and covered with some kind of waterproof substance. As far as i can see the problems lie here any water sweat or other foreign object than gets into this gauze will eventually will clog this gauze material which at first will affect the altimeter then the meteo. When the gauze has been clogged up severely i gets very dirty indeed which means when it gets wet it takes an age to dry out so if you wear it in the shower like i used to it will never dry out this causes the watch to malfunction quite severely. You can actually fix this problem yourself just get a very small flat screwdriver and lever the back off don't worry it's only a push fit and comes of easily you will see straight away a dirty damp smelly clogged up round piece of nylon gauze clean this up with a bit of WARM not boiling soapy water being careful not to disturb the pressure sensor and it's waterproof goo inside then dry it all and put it together
Hope this helps
Dom
England
Feb 12, 2007 | Tissot T-Touch T33159851 Wrist Watch
Watches Logo
54 people viewed this question
Top Watches Experts
Janelle Schoonover
Janelle Schoonover
Marvin
Marvin
Are you a Watch Expert? Answer questions, earn points and help others
