Try typing the following on YouTube:
How to hard start LG G8. Read/listen carefully as an option might include ERASING your data.
OR
You could do a factory reset but risk losing all your saved data if it was not backed up somewhere:
Turn off your LG G8 ThinQ. Press and hold the volume down and power buttons at the same time. When the LG logo appears, keep holding the volume down button but release the power button and then press and hold it again. Release both buttons once the “Factory data reset” screen shows up.
SOURCE: security code
http://www.demonoid.com/files/?uid=1782540
has lots of handy stuff for the u740
use cdma workshop and you can get your phones lock and spc code easily
SOURCE: LG shine
the phone may need to reflash so you should take the phone to a mobile service center and have that done or try the lg website for more assistance.
SOURCE: stuck on startup screen
it looks like your software firmware is damaged and your phone will need 'reflashing' this can only be done at a phone shop and should not cost too much
SOURCE: factory reset for zte msgm8 2 while locked
You may try default phone and security code to remove restrictions.
ur defalt phones codes is 12345 or 00000 u can use it
Default 4 Digit user code: 1234 or 0000
Default 6 Digit Security code: 123456 or 000000
Type *#06# at the mobile screen to know IMEI no of your mobile.
send the IMEI no to me and i will reply you with unlocking code.
IF Problem not Solved So
Please New Software install in the Phone Problem will Solved
