SOURCE: Olympus VN-3100PC Digital Voice Recorder "Err" Message
Download the digital wave player and install it. That will work for your VN-3100PC http://www.olympus.it/consumer/2590_software.cfm?category=0&productgroup=347&product=421&os=7&result=
SOURCE: i can't transfer my files from recorder to pc
This problem can typically be solved by unplugging the device from
your computer's USB port and plugging it in to another USB port on the
same computer.
Also be sure you have Olympus Digital Wave Player installed and open with your Transfer Options set to Auto Transfer. To do this, follow the steps below:
Open Digital Wave Player > select Transfer from the menu > select Transfer Options > under Auto Transfer, check the box which reads "Transfer all audio files after detecting Recorder."
SOURCE: reinstall software needed for Olympus VN-21000PC, no CDRom
I NEED THE SOFTWARE FOR OLYMPUS VN-21000PC. I LOST MINE .I NEED TO WORK ON NOE. SO PLESE DOWN LOAD THIS SOFR WARE
SOURCE: Unable to record
I was using my voice Digital Recorder VN-6200PC. I was recording a my lesson when the screen shows formatting, I immediately took out the battery as not to lose any data, because I was taping and it began to format and I lose the data I was recording. So this time I remove the battery. However when I put back the battery it began to say imput blocked. Please help?
