You do not need a repair manual to do it , its fairly easy job, you can usually google it or you tube repair my fridge thermostat and it will show u how
Would like to replace Freezer Thermostat and/or He - heating element testing fridge heater element-undefined-undefined-5.jpgnt-undefined-undefined-5.jpg" alt="heating element testiWould like to replace Freezer Thermostat and/or He - heater element location -undefined-undefined-9.jpg" class="h_mi" />
SOURCE: Samsung RS2630SH Side by Side... Problem:
I don't have one to offer, but I have removed and fixed the fan, so I can offer you these suggestions:
1. Disconnect the power.
2. The fan is located at the back of the unit behind the removable panel. The panel is held on by about 8 Phillips machine screws.
3. Disconnect the fan by unclipping the connector; simply push the tab on the front and pull straight down.
4. The whole fan assembly pulls out by sliding the fan case out towards you. It may take a bit of a pull as there are tabs holding it in. Once it's loose, you will have to turn it sideways to get it past the condenser tubing.
5. Replacement is exactly the opposite operation; the fan assembly will push into place. You'll here a click when the tabs have engaged.
SOURCE: SAmsung rs2630sh
this modle is automatic you need not to defrost it if you have any ice formation broblemin freezerbdy there must be a door dagket gape plz check that
SOURCE: Samsung RS2630SH Side by Side Refrigerator Door heater
this isnt an electric heater in between the doors its a hot gas loop. there is a motor behind the refrig that cools the comp and condenser coils this fan is either not working or something has jammed it up. just pull the refig away from the wall remove the compartmnet cover and check that fan out good luck peyton
SOURCE: Samsung RS2630SH is hot
i doubt it is really hot but it needs to be warm it avoids condensation around the doors
SOURCE: Samsung Refrigerator model number RS2630SH Getting
Welcome to FixYa.
I`ll start by letting you know first the heat between the doors is normal...to a degree, and done by design to help prevent moisture along the "breaker strip"/divider.
If all else appears fine, temp. Ok, fans running, no significant frost build up on freezer back wall, it's likely nothing to be concerned about.
**Just be sure the condensor fan isn't jammed and still turning.** The fan at the back next to the compressor...
i.e.
Your actual condensor fan assembly may differ in appearance, but generally this is what to look for.
But just so you know, the amount of heat can be determined by several factor's such as,
1) temperature setting - lower ( colder ) the temperature is set the more the run time the hotter the strip.
2) The ambient temperature - hotter the environment the more the unit runs to compensate, hence the hotter the strip.
3) The amount of "fresh" content added to the unit ( especially freezer section if unfrozen items added ) - new items add a lot of warmth thus demanding the unit to run more to remove this heat (btu`s or british thermal unit`s )causing the strip to be hotter.
4) Build up of dust & dirt on the condensor coils - this also causes the unit to run excessively which in turn makes for more heat on this strip.
These are all things which can and do determine the amount of heat between the doors.
Another factor to always consider is of course If it is hot where you live the unit may just be running more to compensate as with other factors I mentioned.
Hope this answer's your question and let me know if I can assist you further.
Thank's for coming to "fixya" and good luck moving forward.
Please take a second to write a brief testimony and rate the info provided here.
Regards,
Macmarkus :)
