Question about Frigidaire Washing Machines
I have a Frigidaire front load washer. Mid cycle it froze up and stopped running. I can't unlock the door to get the wet clothes out.
  • 28 Answers
If you have an appliance that is electronically controlled and has a display panel but settings seem to be "stuck" you can try this. No guarantee that it will work for your situation but you can try to reset the control panel by unplugging it for 10 minutes then plugging it back in. This may or may not help but it works every time my dryer gets stuck on or off with the panel display showing something odd, or stuck on so many minutes left but it doesn't ever stop. It won't cost you anything to try this. If it happens very often you may need the panel replaced.
Posted on Oct 27, 2019
    Top Expert:
  • Frigidaire Master
  • 30,365 Answers
Unplug it and count to 10 and plug it back in.
If that doesn't work, remove the drain hose from its clips and lower the hose into a bucket. The unplug it and plug it back in. The water level switch also controls the door lock.
6ya staff
SOURCE:
Madflower
  • 19 Answers
SOURCE: noise/not draining on spin cycle
I had that problem and it was the drain pump trying to drain but it coulsn't because it had lint, plastic, 3 underwires a looney some costume jewellery stuck in the pump. By the pump underneath you'll see a black plastic boot leading away from the pump. disconnect this and inside you'll find the lint trap and if you dig you'll probably find the culprit that stopping your pump from moving. Put it all back together and Voila!
Posted on Jan 25, 2009
Anonymous
  • 277 Answers
SOURCE: Kenmore front load washer will not spin. Clothes come out wet.
The clothes are wet after spinning When the clothes are wet at the end of a cycle, check these:
Motor coupler
Spin cycle
Siphoning
Water-inlet valve
Motor coupler To test the motor coupler, re-start the washer in its spin cycle. Let the machine run for a minute, and then open the lid and notice whether the tub is spinning:
  • If it's spinning when you lift the lid, the coupler is fine.
  • If it isn't spinning--and your machine was produced by Whirlpool®--you may have a broken coupler. Many Whirlpool-made washers use a small, relatively inexpensive device called a motor coupling. This plastic-and-rubber component is mounted to the shaft of the motor on one side, and to the transmission on the other. Over time, the coupler wears out and fails. When that happens, you need to replace it completely.
Spin cycle If the washer doesn't reach its proper spin speed, the clothes may be too wet at the end of a cycle. Check to be sure the load is properly balanced and run a spin cycle again. If the clothes are still wet, you may have a worn or loose belt (Maytag®), a worn clutch (GE®/Hotpoint®), or a worn motor pulley or tub bearing. Replace the applicable component.
Alternatively, there could be clothes caught between the inner and outer tubs. Read the "It spins but won't pump" section of the "It won't drain" section. Also, there could be other things that cause friction on the drive train. Seek the assistance of a qualified appliance repair technician.
Siphoning If the water that pumps from the machine goes right back into the machine after the spin cycle, it may be because your washer is siphoning the water from a laundry tub with a slow drain, back into the washer. Try to improve the draining of the laundry tub. (Is there something stuck in the drain?) Also, be sure the drain hose doesn't reach more than about 4 inches into the laundry tub. If it does, cut off the excess.
Water-inlet valve Water-inlet valves eventually fail. One problem that may develop with a water-inlet valve is that it can no longer completely shut off when the electricity is turned off to it. Then, the valve may leak and drip water into the clothes tub--you may notice that your washer has water in it when you haven't used it for a few days. To fix this, replace the valve.
Posted on Mar 02, 2009
Anonymous
  • 72 Answers
SOURCE: LG Tromm WM2496HWM Washer - stops mid cycle
use only HE (high efficiency ) soap,try not to use too much ,run tub clean cycle with a little bleach to kill smell
Posted on Jun 19, 2009
Anonymous
SOURCE: Door locked on compact Whirlpool front-load washer
This worked for me. I turned off the washer and hit the area on the washer directly to the right of the door handle (not hard enough to break something or cause a dent). It popped right open.
Posted on Sep 30, 2009
Anonymous
SOURCE: Front load Frigidaire Gallery washer
how to changethe door around on a front loader washer
Posted on Dec 29, 2009
Clothes Washer stopped running. I have a Maytag PAV2300AWW clothes washer that was mistaken ran with a full load on the small load setting and stopped working mid cycle. Any help with the cause and
first check the house breaker and make sure you still have power. If it does then I would unplug the machine and lean it back against the wall to look at the motor wiring harness underneath to see if it came loose or is wet.
Mar 31, 2012 | Maytag PAV2300 Top Load Washer
Clothes sopping wet at end of all cycles
Here is a tip that I wrote a bout front load washer spinning and draining problems...
Front Load Washing Machine not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
May 16, 2010 | Frigidaire ATF6000ES Front Load Washer
Asko w6021 washer leaves clothes damp and often stops mid cycle
I AM NOT MUCH OF A MECHANIC, BUT I DO KNOW THAT IF WATER DOESN'T SPIN OUT OF THE WASHER, IT COULD BE THAT YOUR BELT IS BROKEN OR YOU NEED TO REPLACE THE MOTOR COUPLING.
May 13, 2009 | Asko W6021 Front Load Washer
Control locked
Hold the 'options' and 'select' buttons down at the same time for several seconds, the thing will unlock.
And rate me pl..................
Jun 14, 2008 | Frigidaire GLTF2940ES Front Load Washer
You are having a door switch problem change it out and you will have a new washing machine.
Dec 14, 2007 | Frigidaire GLTR1670A Front Load Washer
Washing Machines Logo
57 people viewed this question
Top Frigidaire Washing Machines Experts
Gerry Harvey
Gerry Harvey
J. Bradshaw
jimorris77
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
