Retail Supplies Logo
Binheng Yang Posted on Oct 28, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Casio cashier sr-s920 cant work, I can't update the date by keyboard enter.
Attique-ur-Rehman
Level 3:
Top Expert:
  • Master 2,677 Answers
  • Posted on Apr 15, 2020
Attique-ur-Rehman
Master
Level 3:
Top Expert:
Answers
2677
Questions
Helped
878085
Points
8006
Https://www.youtube.com/watch?v=HUf2UseADyw
3 Related Answers
Anonymous
  • 737 Answers
  • Posted on Mar 13, 2009
SOURCE: extract data from a casio te 3000 cashier
Hi.
The common software is CasioVision (CV). Check with a local dealer for software and cables.
Electroboy
Electroboy
  • 1888 Answers
  • Posted on Dec 08, 2012
SOURCE: Program a cashier onto a Casio TK 7000
It should be the 05 file on that machine so you just add the cashier number in front of the file number (105 for cashier 1, 205 for cashier 2 etc). So go to program 2 then use the 05 code as I've said to edit the text. The text entry procedure is shown in the manual so just run through that to familiarise yourself.If you don't have the text entry information in your manual, then you have the wrong one. You need this one:
http://the-checkout-tech.com/manuals/cashregisters/Casio_TK-6000_TK-6500_TK-7000_TK-7500_TK-T500_CE-6000_etc_dealer_manual.html
gopakumarg43
  • 76851 Answers
  • Posted on Sep 20, 2015
SOURCE: Bought a chunghop E-S920 sanyo type remote for my LCD TV model 26XRDA0638. What's the code to sync them? How do I enter the code?
0184,0140,0142. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Only one flashing zero on casio SE G1 date set up instead of 6 zeros when turned on?? so cant put date in/
Have you set the date format first? When entering the date, use the Xtime button
How can i change the name of the item?
If it is a department key, find the department text programming sequence in the manual. It will show you how to enter text from the tables or keyboard during name changes. If it is a PLU key, use the PLU text sequence. If it is a cashier or clerk key, use the cashier or clerk programming sequence.
If you need a manual, one of the users has huge listings here:
Hope that helps
1helpful
I cant set the date, because I got the battery replaced and I the date is two days late
Use the manual to set the correct time zone, time and date. Manual is available on the Casio worldwide website>support>manual>watches.
Have the module number at hand: you will enter it to find the manual. The module number is a 3 digit or 4 digit number on the back of the watch.
Casio TE2200 stuck in INIT mode and wont let any cashier log on. I have just done a factory reset and set time, date, dept names, and cashier names. Now no-one can log on or off and it seems the till...
It sounds like you might have used the wrong clerk system in your MAC code. If you use a single clerk button on keyboard, you need clerk code set in the MAC code. If you use the clerk buttons at the top of the keyboard, you need to set clerk key in the MAC code. If you tell me the MAC code you used during the reset, I can see which system you are using.
If anyone needs a Casio TE-2200 manual, try here: http://the-checkout-tech.com/manuals/cashregisters/Casio4.php
Got casio qt2000 till, using hospitality 1.35 build 181. Single connection to PC com3:, no printers terminal only and cash draw. Simple single bar senario, Drinks, Read takins and item groups at end...
I think you enter date in std Casio format: PGM1 mode, Type YYMMDD then press X/TIME button
If you go to Z mode and try a report, what happens?
If anyone needs a manual for a Casio QT-2000, C-tech collective have User/ Programming, service manuals here: http://the-checkout-tech.com/manuals/cashregisters/Casio3.php
Extract data from a casio te 3000 cashier
Hi.
2helpful
2answers
CASIO TK 7000 cash register how to change the time
pgm 1
enter 24Hr Clock
0900 or 2100
press the date/ time button
next to the C Key on standard keyboard
2answers
CASIO PCR-265P
Hi.
Please tell me exactly what buttons you pressed to set the cashiers and I'll see what you did wrong.
Mark
1helpful
2answers
Casio cashier
Hi. You haven't given a model number, but it usually means you haven't logged on. press 1 then CLK#. If your machine has a row of buttons just under the keylock called clerk, then make sure one of them is pressed down.
Mark
Top Retail Supplies Experts
ADMIN Andrew
ADMIN Andrew
Ngoro
Are you a Retail Supply Expert? Answer questions, earn points and help others
