Question about Cell Phones
How do I add and delete numbers on a Curry’s essential C22DECT10 in the phone book?
    Top Expert:
  • Cell Phones Master
  • 66,248 Answers
LOOK IN ADDRESS BOOK
Posted on Oct 28, 2019
6ya staff
SOURCE:
Anonymous
  • 65 Answers
SOURCE: delete old phone number on auto dial and add new one
go here and download users manual by clicking on file name
http://service.us.panasonic.com/operman/findmanual.aspx?model=KXT7630
Posted on Feb 25, 2008
pmkdarts
SOURCE: Address Book - Manual entry
I have just worked it out after numerous attempts!!!
1) Pair your mobile phone with the KCA BT100 (Passcode 1234)
2) Disable the "handsfree" option on the mobile phone for this pairing
3) Select the contact you want to send, bear in mind that the maximum you can send is 300!
4) 'Beam' the contact and your phone will search for bluetooth devices
5) Select the KCA BT-100 and press send/enter
A few seconds later the contact will be sent.
Once you have sent all the contacts you wish to send, turn off the car. Enable the handsfree function on the pairing, when you view the telephone screen you will see that the phonebook option has now been highlighted and you can select from the contacts you have just enetered!
Enjoy!!!
Posted on Jun 18, 2008
Anonymous
  • 44 Answers
SOURCE: how to delete and program in speed numbers for fax
Create speed dial entries for fax numbers that you use frequently. The number of speed dial entries you can set up depends on the HP device. For more information, see the specifications for the HP device.
expanded.gifTo manually create a speed dial entry 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Click New Entry. 3 In the Speed Dial Settings - New Entry dialog box, type a name and fax number, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Note If you are creating a speed dial entry for a networked HP device and you are unable to save the entry, another user on the network might have accessed the same speed dial. Wait a few minutes and try to save the entry again. expanded.gifTo create a speed dial entry from the Address Book 1 In the HP Solution Center, click Settings, point to Fax Settings and Setup, and then click Fax Speed Dial Settings. 2 Under Address Book, click Select From. 3 In the Address Book dialog box, select one or more names, and then click OK. 4 In the Speed Dial Settings dialog box, click Save. The entry is stored on the HP device.
Posted on Sep 11, 2009
Peter Dragonetti
  • 798 Answers
SOURCE: how do you add a phone number to the address book of a Uniden cor
Hello there and welcome to lfete at Fixya, the Support Team
Normally you add a new number to the phone in the feature contacts. Go to there and select add new and type the number name etc. :O)
Hope that helps
IF NOT then try to return here
Have a nice time over there
Please rate my answer
Posted on Jan 02, 2010
Anonymous
SOURCE: Insufficient privileges
you usually have to admin rights to do that
Posted on Jun 04, 2010
How do i delete and add numbers to the phone book option
when you get to add numbers section you will see edit
click on that and that allows to enter name and numbers
remember to ok and save
May 20, 2016 | Panasonic KX-TG2432 Digital 2.4Ghz...
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
I wish to add new contacts and delete obsolete one. Help!
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again. You will see the message Successfully Added and you are done!
Dec 18, 2010 | One Touch Jitterbug One-Touch Cellular...
Apr 08, 2009 | Western Digital My Book Essential 1TB...
I am unable to delete. Following instructions to no avail.
on the main page, touch the blue phone icon.to open the phone menu then, touch the phone book icon. it looks like a phone book in the top left hand corner of screen. you can add numbers here.
Mar 10, 2009 | Garmin StreetPilot c550 GPS Receiver
Can't open the phonebook of my motorola e398
Motorola E398/Razr address book disappears/bounces:--Solution
press 1+# (i.e. speed dial #1)
press Menu -> Categories -> Select -> All
Bingo. U r now in the Address Book --delete all entries which have no names against names or add some name.
Dec 11, 2008 | Motorola Mobility E398 Cellular Phone
I need to remove a # from the rejection list
go to - menu-> settings-> application settings->  call->  all calls->  auto reject-> (scroll one down) reject list->
[on the reject list uncheck number you wish to remove from the reject list. ]
-this is the most accurate answer, trust me.
Jun 18, 2008 | Samsung Cell Phones
Cannot edit stored phone numbers
goto phone book hit menu find the number and or persons name you want to edit edit the number hit ok to get to the number or you can do the easier way
delete there name and number and put it back in with the right digits
May 30, 2008 | Uniden Cordless Phone
Unable to Store Phone Numbers
The store memory function is very similar to this phone in the EXA series phone made my Uniden.
See the instructions to store/delete/add numbers in the manual below on page 22.
http://www.uniden.com/pdf/EXAI2248Iom.pdf
hope this helps
- Pete
Jan 31, 2008 | Uniden Cordless phone EXS9950
Deleting phone book entries
Hi cburke. Had this same problem. go to the phonebook, scroll to the number you want to delete and then press menu. it will take you to the edit screen then select delete, or whatever you want to do with the number. Simple really, but instructions with this phone are awful.
ceobarb
Nov 05, 2007 | Motorola Mobility RAZR V3
Cell Phones Logo
300 people viewed this question
Top Cell Phones Experts
Ekse
Marvin
Marvin
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
