Question about Toro Garden
I have a toro snow blower that dosnt idle write How do i fix this Problem
  • Toro Master
  • 2,019 Answers
If you didnt treat fuel before storage last season then likely the carburetor is fouled. Try adding a fuel treatment e.g. Seafoam, but likely ithe carb will need a thorough cleaning or replacement.
Posted on Oct 29, 2019
Anonymous
SOURCE:
trippssmengi
Mark Tripp
  • 76 Answers
SOURCE: screeching snow blower
On one side of your machine you will find a cover that you can remove, the belt for the auger is in there. From what I can see there is no adjustment. Check to see how the belt looks.If it's chewed up it will need to be replaced.If you remove the belt try to turn the impeler to see if it turns freely, if it doesn't then check to see if there is something wedged. if nothing is wedged and the belt is off and it still don't turn by hand it could posibly be a bad bearing.if it does turn by hand. Also check the belt pulleies to see if they are ok, the only pulley that will sshould spin freely is the idler pulley, the one on the engine shaft should spin the moter so make sure you pull the spark plug wire off to check that one, and the auger pulley should spin with the auger.
Posted on Jan 15, 2009
240cpa
  • 548 Answers
SOURCE: Snow blower spark plug replacement
I would check it at the start of every season and clean it. If you note that it seems to be running rich and might have fouled the plug, you can always pull it and check it again. Probably not a bad idea to check it before you put it away for the season. As for replacement, it depends on condition. I would think that you should get two or three season's use out of it before needing to replace it, at least.
Posted on Jan 25, 2009
Anonymous
SOURCE: carb adjustment
Screw both screws right in (don't force them) Then turn each screw out 1 & half turns each OUT. This will get engine running. To fine tune- turn low speed screw out, bit by bit, while idling, till engine revs change, then turn screw in till revs change, the correct setting will be somewhere between the 2 adjustments you just made. Do the same thing to the high speed screw, but with full revs. Good Luck. Stevo..
Posted on Feb 18, 2009
Anonymous
SOURCE: My toro 1128 OE snow blower wont throw snow the
I have a toro 98 cc powerlite snowblower model 38182 it was running fine one day then bog down and died after that i cant get it to start it has a good fire on the plug plug isnt very wet it pops threw carb once in a while help
Posted on Dec 27, 2009
Anonymous
SOURCE: toro snow blower leaks gas from carb will not run
i have the exact same problem...anyone?
Posted on Feb 08, 2010
Snow blower shorted out
If you're Toro electric blower is slowing down, throwing sparks, overheating or not starting you may need to replace the carbon brushes. Replacing brushes and cleaning commutator early can prevent damage to motor armature!
There are Electric Motor replacement carbon brushes on E-bay for all three motor sizes (7 AMP, 10.5 AMP, and 12 AMP) of Toro Leaf Blowers (Toro Rake and Vac Super and Ultra Blower and "850" Vacuums)
Search E-bay for: "Toro Blower Carbon Brush"
- 12 Amp leaf blowers Toro Super (Old model 51552) through Toro Ultra (New model 51609).
- Toro 850 Super Blower Shredder-Vac 12 Amp (model 51575).
- 10.5 Amp leaf blowers Toro Old through Toro New model 51573.
- 7 Amp leaf blowers Toro model 51586 and other Toro 7 amp blowers.
Feb 17, 2014 | Toro 51599 Electric Blower 12 Amp
Auger rattles so bad on idle, toro power max 926 oxe
bad bearings on the ends , this I would have to see but this is prob it or loose bolts on the auger grab with your hand and see if it is loose anywhere , not running of corse
Dec 15, 2013 | Toro Power Max HD 926 OXE 26 inch 265cc...
Won't start
The carburetor on your Toro 418ZR snow blower is located on the right side of the unit above the rear wheel (if standing behind the snow blower). You will have to remove the top main cover and the starter housing to access the carburetor cover and assembly. Here's a part diagram that may help out: http://www.jackssmallengines.com/Jacks-Parts-Lookup/Manufacturer/toro/5860/62997
Dec 15, 2013 | Toro Power Clear Snowblower 418ZR - 38272
I have a toro snow blower that wont throw snow
then you need to see if the belt is still in one piece... then inspect what else would cause this issue
Oct 10, 2013 | Toro Snow Blower Ccr 1000 Belt 715381...
Toro snowblower wont start.I have a toro ccr powerlite that dosnt seem to be getting fuel from the fuel line into the carb. I took the fuel line off and fuel is getting to the carb so then i removed carb...
Reference the Toro snow blower. It may sound crazy but loosen the gas cap just a bit. I had the same issue with my snow blower and a friend gave me the solution. It works great now. Hope this works for you.
Oct 21, 2011 | Toro Lawn Mower With Toro Power Tools
My snowblower just started back firing,why?
Snow is melting on the engine and causing the spark wiring and/or magneto to short out...
Stop blowing snow and run the engine at a fast idle for awhile to dry off the motor...then it will work again..
heatman101
Feb 25, 2011 | Toro Snow Blower Ccr 1000 Belt 715381...
My Toro snow blower requires leaded fuel. Can I
I would not reccomend it. just buy some lead additive at any auto store or automotive department & mix per the directions.
Nov 15, 2009 | Toro Blowers Rake and Vac - Electric...
Will not throw snow
I have a toro 421 snowblower won't start after had it fixed from shop and how to operator to starter?
Jan 15, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
49 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
roeb
Marvin
Marvin
Are you a Toro Garden Expert? Answer questions, earn points and help others
