Question about Sony Televison & Video
I have a Sony Bravia KDL-40S4100 TV that will only turn ON and OFF........no other functionality of the other buttons. Can this TV be saved?
The up/down channel buttons, the up/down volume buttons and the menu button have no effect on the operation of the TV same with those buttons on the remote. The TV always comes on to the same station with a low sound volume when turning on and off.
6ya staff
SOURCE:
Anonymous
  • 121 Answers
SOURCE: theres no picture on my sony bravia KDL-40S4100
Try pressing the TV/Video button. The problem could be that the TV is set to an input with no source.
Posted on Feb 25, 2009
Anonymous
SOURCE: KDL-32M4000 sony tv screen went black suddenly,
We are having the same problem! Whats the solution!!!?!?!?!?!!!?
Posted on Nov 26, 2009
Anonymous
  • 51 Answers
SOURCE: I have a 42" Sony Bravia KDL-40S4100
Probable power supply
Posted on Dec 15, 2009
budmrtn
Bud Martin
  • 11361 Answers
SOURCE: Sony Bravia KDL-V40XBR1, no picture
You either have failed 24vdc power supply section or failed backlight inverter board, check for 24vdc first, look for caps with leaking/bulging top.
Parts: http://www.shopjimmy.com/catalogsearch/result/?q=Sony+BRAVIA+KDL+-V40XBR1+
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on Jun 13, 2010
hoodpeter
hoodpeter
SOURCE: YSP: Need remote code for TV Sony Bravia KDL-46W4500
I have the sony KDL 46 EX720 and got the code 2751 to work.
Posted on May 03, 2012
Sony bravia KDL 40S4100 No picture
If you wish to get some details; check the site linked here. Pull up older posts.
Troubleshooting procedure for No-Picture is given in detail.
Sep 06, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony bravia 5 blinks
Hi Tradeboyle,
Please search 'Sony Bravia KDL-40S4100 40 in five blinks' on google and you will get several videos containing the solution of your problem.
Good luck.
May 12, 2016 | Sony Bravia KDL-40S4100 40 in. LCD TV
I have a Sharp TV model LC-32SB24U. I cannot access the menu screen because I lost the remote control. Is there another way I can change channels without a remote?
The Sharp LC-32SB24U has menu, input, volume up/down and channel up/down buttons on the top of the TV. When you access the Menu using the buttons on the TV, the Input button is the same as the Enter key. The volume up/down buttons map to the left and right arrows. The channel up/down buttons remain up and down. The Menu button is the closest to the power button (on the right). The volume buttons are the ones on the left.
Make sure that the input is set to TV to change channels. Then you need to program the available channels, access the Menu and navigate to Setup (left/right arrows). Press Input to enter this sub-menu. Then use the Up/Down arrows to select CH Setup. Press Input again to enter. Now you can set the channel source and let the TV scan for channels that have a strong enough OTA signal or are unencrypted cable channels. These are the top two options in the Channel Setup menu. The details are available in the manual which is available here: http://static.highspeedbackbone.net/pdf/Sharp_LC37SB24U_LC32SB24U_Manual.pdf . For OTA channels, you may need to check the signal strength under the Antenna Setup - Digital option in this Setup menu. OTA Digital signals will not be tuned in if the signal strength is low. It's an all-or-none tuning; amplifiers and external antennas may help. See tvfool.com for details of transmitters and the recommended antenna for your area. (Warning: damaged amplifiers can become filters and block the signal on some channels. Replace the amplifier if it is damaged.)
If you look to replace your original remote with a universal remote, you'll need one that was programmed more than 6 months after the TV was released. That may be 12/2005 based on the manual copyright date. Look for a remote that has a Menu and Input or Source button and check all of the codes to find one that matches all of the features on your original remote. Amazon has an OEM remote for the LC-32SB24U; remotes.com also has a replacement remote available that has been programmed for the TV. (On remotes.com, search for the LC32SB24U.)
I hope this helps.
Oct 26, 2015 | Sharp LC-32SB24U 32 in. LCD TV
Reprogram channels on my Westinghouse tv model sk26h520s for a new location
Make sure that the source is set to TV. If you use the original remote, press the top button between the volume up/down and channel up/down buttons. If you use the buttons on the side of the TV, the Source button is next to the Channel Down button.
Next press Menu. (On the TV, it's the top button. On the remote, it's the top left button next to the arrow keys.) Now navigate down to Channels (use the Channel down on the TV) and press Enter on the remote (or Menu on the TV). Navigate down to Scan Channels and press Enter or Menu (as needed). Choose Antenna or Cable, depending on your source and press Enter again. (Note: the volume buttons on the TV are your left and right arrows in the OSD.) If you get a confirmation notice, select Yes and press Enter.
I hope this helps.
Dec 31, 2014 | Westinghouse Televison & Video
My sony bravia 40'' TV video in 1 and 2 is showing lock, how can i go about it.
try to reset tv from service menu sony service menu display 5 vol+ power from remote and see the reset menu and reset whole tv functions.
Dec 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
KDL-40s4100 power light on, black screen
Main PCB is bad . I just got the information from a Sony authorize servicer price for the part only $504.87
Nov 27, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
There is a big block in my TV screen covering 8 to 10 inches. I have a Sony Bravia, model KDL-40S4100, and i bought it in 2008.
if it is a black block, look in the menu under closed captions and see if it is in the text mode. if so change back to cc1 or turn off.
Aug 19, 2011 | Sony Bravia KDL-40S4100 40 in. LCD TV
Hello, This Sony KDL 40S4100 is only recieve NTSC signal, is there is any firmware or anyway that I can make it recieve PAL signal??? Thanks for your help.
This is another Sony KDL 40S4100
Anybody out there?
Sep 07, 2010 | Sony Bravia KDL-40S4100 40 in. LCD TV
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
Televison & Video Logo
19 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
