Do a factory reset to this set, and then check. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
https://remotesearch.blogspot.com/
https://electrohelponline.blogspot.com/
https://electronicshelponline.blogspot.com/
https://homenol.blogspot.com/
SOURCE: Remove base of Insignia ns-ltdvd26-09
to remove base from insignia tv
1)remove plastic cover from bottom rear of tv
2)remove 8 philips head screws on rear of tv above base
3)pick up tv and base will come off
once you remove it you realize how easy it is
SOURCE: insignia NS pdvd10
Unlock
Insignia NS pdvd10
It`s really works
1) On the remote control type "SETUP" button
2) Select "PREFERENCES" in the menu with
3) Validate it with the button "OK"
4) Enter the code : "224455"
5) With the direction keys type:
a) Left key : < (Nothing happens)
b) Down key : v (a menu appears on the screen
with all region)
6) Select the Region : 0 (all) with the direction keys
7) Validate it with the button "OK"
8) Finish the process by typing the "SETUP" button.
Unlock
Insignia NS pdvd10
It`s really works
with all region)
SOURCE: Insignia NS-LCD37-09 turns on but no image
If your TV is less then a year old, still under manufacturers warranty. If not under warranty the defective parts could be the power supply or the back light inverter board. Both boards can be replace easily.
The way to know if you have a defective backlight inverter is by shinning a light from a flash light near the screen with the TV on and check in a 45 degrees angle if you have a dark video in the background, if the video is present then you have a backlight board failure. If no video, then is a power supply failure.
I have both boards if you want to buy them.
Let me know if you require further assistance.
Our insignia tv did this. Menu kept popping up, on and off, until we were ready to throw the tv out the window. We factory reset the tv and it hasn't done it since. Google instructions on how to factory reset the set, and all done.
