Question about Light Office Equipment & Supplies
My NEC-PA550w It won’t turn on and has status light blinking 9 times. What does that mean?
6ya staff
SOURCE:
Anonymous
  • 115 Answers
SOURCE: lamp not lighting
Reset the lamp and try it.
Posted on Mar 29, 2008
babes_ganda0
Nelson Olaso
  • 381 Answers
SOURCE: "[9]" labeled status light blinking and no display
open the case then locate the memory and make a clean all pin connectors of memory using a paper eraser..
Posted on Jul 08, 2009
Anonymous
SOURCE: NEC VT 595 wont turn on. Just red blinking light
I had this same problem with 2 NEC VT595 projectors. My problem was that there was a broken "tab" on the lamp cover (the plastic cover that slides in place over the lamp) that is supposed to depress a switch which insures the lamp cover is in place before operating the projector. The tab was broken in half and not making the connection there for causing the blinking status light (.5 sec on, 2.5 sec off) indicating a lamp housing or cover error.
Posted on Aug 26, 2009
hawk127311
CURT
  • 350 Answers
SOURCE: the tv wont turn on. the red light blinks 9 times.
There is a problem with one or two of the diodes on the G board.
Zero Crossing Detector 9 times 9:0 or 9:1
Probable cause • D6116 or D6301 is open (G Board)
symptom • No picture
I hope this helps and good luck!
Posted on Nov 11, 2009
Joe Peacock
SOURCE: NEC VT595 Projector - Status light blinks red constantly
We had this same problem. In our case it turned out that a little bit of plastic broke off of a tab on the inside of the plastic lamp cover. Without that piece it was not pressing against the sensor that tells the projector that the lamp cover is closed. Without that, it doesn't start. We got it working again by drilling a little hole and sticking a screw through that spot to replace the missing plastic, but I'd rather replace the cover if I could. Really dumb that a little piece of plastic can mess up thousands of dollars worth of equipment (Smartboard 2000i).
Posted on Nov 28, 2011
What would cause the status light to blink and the projector not turn on. NEC-NP50
Could be a bad power supply, or lose connection try another one
Aug 14, 2014 | NEC NP50 Projector
Nec vt540 vt540k
probably needs filters cleaning or a new lamp replacement.
Oct 07, 2013 | NEC VT460 Multimedia Projector
Status light blinking
Sometimes the fan overheats. Pull the power plug out of the back for about 15 - 20 minutes. Then plug it back in. 95% of the time that will solve the blinking status light problem.
Feb 20, 2013 | NEC NP2000 Multimedia Projector
My nec np-m300x has a dynamic contrast error. How do i repair this?
9 Blinks is IRIS error the motor can sometimes produce a clicking sound part number 24B17981. If you pull it out and manually move the metal apart the projector should come on and stay on
Jan 23, 2013 | NEC NP-M300XS- Xga Lcd Proj 3000lumen Shrt...
Won't turn on, light flashed 9 times
the 9 blinks is indicating a panel SOS which means the Panel itself is whats causing the 9 blink error code.
Mar 24, 2012 | Panasonic Viera TH-42PZ85U 42 in. Plasma...
Does a lamp error message (6 blinking red status lights) mean the lamp needs to be replaced? or could something else be wrong.
According to NEC technical support, if the status light flashes red six times, this could indicate a defective lamp. If a new lamp is installed and the project still won't turn on, the projector will need service.
Jun 15, 2011 | NEC NP400 Projector
My nec vt595 wont start up the status light is flashing orange
The only time the "status" light will be orange is when you accidently press the cabinet button and the cabinet is locked.
However, if the "power" light is blinking orange it means that the projector is cooling down and you need to wait a few minutes.
Jan 03, 2010 | NEC Computers & Internet
Status lamp blinking orange 6 times
PROJECTOR. NEC VT491 THE STATUS LIGHT IS BLINKING 6 TIMES RED, AND THE POWER LIGHT IS ORANGE
Jun 26, 2009 | NEC Office Equipment & Supplies
26 people viewed this question
Top Light Office Equipment & Supplies Experts
Marvin
Marvin
Copy-Tech
Level 1 Expert
Are you a Light Office Equipment and Supply Expert? Answer questions, earn points and help others
