Question about Tablets & eReaders
How do I delete this app - Tablets & eReaders
  • Not Me
    Not Me Nov 01, 2019
    Hi Paulette Mathews, I want to help you with your question, but I need more information from you. Can you please add details in the comment box? Can you tell us what app you want to delete, and what device you are using?
How to delete candy crush from my iPad permanently
Touch the app and hold your finger down until all the apps start to jiggle. You will see a circled "x" in the upper left corner. Tap it to delete an app. When done press the Home button.
You cannot delete any pre-installed iOS app.
If there is No 'X' on any apps you have Downloaded... then check in Restrictions... Settings > General > Restrictions > Deleting Apps = Off / On
If the app is in iTunes, then you delete the app in iTunes (Select the App and Press Delete on your Keyboard). If you then sync with your iDevice, the app will also be deleted from your iDevice.
Dec 06, 2016 | Apple iPad Tablets & eReaders
I cannot delete my apps
press on the apps icon you want to delete for a few seconds until you see it shiver
press again and it is gone
Nov 14, 2015 | Tablets & eReaders
Im trying to delete apps on my iPad because the
Lightly place your finger on app you want to delete and hold there til it starts blinking then delete apps you want to delete
Sep 24, 2014 | Tablets & eReaders
How to delete apps in iPad
On the homepage of your iPad > find the app you want to delete > long press it until it wobbles > press the cross on the top-right of the app to delete it.
Sep 03, 2014 | Apple iPad 32 GB 3G Tablet PC
How do I delete a banking app on IPad Air
press and hold finger on app icon, until it and all other apps start wiggling and display an "x" near the icon. release finger and press on the "x" for the app you want gone and it will disappear. Then press the home key to get out of the delete mode.
Aug 21, 2014 | Tablets & eReaders
How to delete unccessery apps on a iphone 4?
Tap and hold on the app icon until it wiggles. Tap the X at the corner of the app to delete. Answer the "OK to delete" question. Repeat for other apps. When done, tap the Home button to return to normal operation.
Mar 10, 2014 | Apple iPad 32 GB 3G Tablet PC
How to delete from ipad
delete Apps:
there are 2 different ways to delete an App:
1) t's easy to delete apps from the iPhone or iPad. Simply tap and hold on any icon for about 2 seconds - see them to start to wiggle and tap the X button in the left corner. that's it.
2) For devices running iOS 5 and later, there is also another way to do this is hidden in the Settings app, in the General tab, under: usage.
- you can manage the apps on your iOS device. Once there, you'll notice (after a certain delay if you have a lot of apps) that your on-board apps are listed in descending size order. That means: the apps that take up a lot of space will be listed first.
Tap on any app and you'll get even more info, including the version, the size of the app and the size of the Documents & Data. Just below that, you'll have a Delete App button in red. At the very bottom, you'll see how much space is available on the device itself.
Deleting apps that take up too much space is helpful when you're trying to install new apps, You may even notice apps that have a lot of storage attached to them that you weren't even aware of before like internet radio apps that sync songs to your device to play during the time you're not connected to the internet.
-- however, there are some core apps belonging to the iOS system and cannot be deleted like 'clock', 'calendar', 'contacts' etc.
delete-from-ipad-zh5gubleqhzqp4way4x4cgqo-1-0.jpg delete-from-ipad-zh5gubleqhzqp4way4x4cgqo-1-2.jpg delete-from-ipad-zh5gubleqhzqp4way4x4cgqo-1-5.jpg
Jan 05, 2014 | Tablets & eReaders
Remove baidu from iPad
Have you installed a Baidu app on your iPad and wanna remove it?
Well, the first method recommended for you is to directly delete apps from Home screen on your iPad.
1. You only need to keep touching the icon of the app until it wiggles with an X at the upper left corner.
2. Then tap the X and choose "Delete" in the pop-up dialog. You will get the apps deleted with no efforts.
Sometimes you cannot see the X and don't know how to delete apps on iPad directly, you can check the Settings at this moment. Then you can try to delete the apps on your iPad again.
1. Check the "Settings", then scroll down a bit and tap on the "General" option.
2. Tap on "Usage" (older version of iOS) or tap on the "Storage & iCloud Usage" (newer version of iOS).
3. You need to tap on "Manage Storage" and you'll see a list of all app installed on your iPad. Simply select the app and tap on "Delete" to delete that app.
There are also some other methods to help you remove unwanted apps from your iOS device. Click the following link to know more.
How to Delete Apps from iPad
Dec 09, 2013 | Tablets & eReaders
Want to delete apps on ipad
On the app you want to delete hold it down until the apps starts shaking and a cross will appear in the apps you can delete. Click on the cross and it will say delete "name of app", then select the delete button. Once you have done this, press the home button to go back to normal. Hope this helps.
Jan 05, 2012 | Apple iPad 32 GB 3G Tablet PC
How to delete apps
You can either delete them from itunes when you plug in your ipad click on the devices and select your ipad then under the tab app you can then choose the apps you want to be on your ipad. Or on your ipad itself press your finger onto the any of the apps until they start shaking on screen the ones you can delete have an"x" in the top left hand corner of their icon, you then click on the "x" and it will then ask "Delete app, Deleting "app"will also delete all of its data" then select delete or cancel. Once you have deleted the apps you then press the home key to start using your ipad again. Hope this helps, if it does please give me a rating.
Dec 06, 2011 | Apple iPad 32 GB WiFi Tablet PC
Tablets & eReaders Logo
104 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
