A camera system for security is what that is, unstated by you which system models.
sounds like the UNIT is damaged to me from lightening surge?
why not contact the maker directly. we make nothing here.
all we can do is point.
USA support
https://support.zositech.com/hc/en-us
click submit a ticket,
SOURCE: Toshiba 42HPX95 wont turn on
I am having the exact same problem with my Toshiba 42HP95. From the information that I have been able to glean from the internet, it looks to be some sort of problem with the power supply or some other component of the power circuit. I am giving up and getting service
SOURCE: Hobart LX 30 P2 Error and unit overflowing!
Hi drogers77,
I'm not a Hobart technician, but here what I founded in my manual for the LX30 error message:
LX18 / LX30 display shows E0, E2, E3 or E4
1. Low water pressure - check for clogged hose strainer; check that site water pressure meets minimum flow pressures.
2. Make sure probes are clean
3. No water pressure - main water supply valves may not be working
4. Drain valve open - turn machine OFF to drain machine, then ON. Repeat twice (this assists in clearing any drain valve obstructions). Wait for machine to reach READY mode and press WASH. Slowly open door several seconds later and note water level. Close door; 30 seconds later, open door slowly and check that water level is the same as it was. If not, repeat the OFF-ON procedure. If problem persists, call your local Hobart Service Office.
5. Delime machine.
Hope it will help you.
pepsicrazy
SOURCE: green light blinking on back of my system unit but there is no power
I had this problem and i tried everything to make it work. Now all i do is put a hairdryer at the back whilst the computer is plugged in until the light stops flashing then switch on as normal. I also noticed that when the air is warm i do not have to use the hairdryer hopes this helps.
SOURCE: When I power up laptop screen is blank
You may have a burned video adapter.
A trouble shoting setp you can try is attatching an external display and seeing if that works.
Also try the function F5 key combo. I think that is the ASUS mapping to switch display output.
