I have a 70 pint unit, which has been in service for approximately 17 months. I have done everything possible to create pressure on the attachment point of the hose and it still drains into the bucket.
SOURCE: haier 30 pint dehumidifier continuous drain problem.
Many just attach the hose at the reservoir; from your description, Haier apparently has a separate location. Check that the point that the hose attaches has an opening (many don't, they expect you to drill it). It should then drain through gravity. Check to make sure that no part of the drain hose is higher than the bottom of the reservoir, otherwise it can't drain. It won't siphon because each time the the tank empties, the suction is broken and the siphoning can't continue.
SOURCE: Dehumidifier
Hey ya! To fix this u need to block that hose connection under the Dehumidifier. This will then re direct the flow to the Bucket collection mode. I have the same problem and resolved it this way after pullng mine apart. It looks like by default that hose connection at the bottom should have a plug/cap on it and after turning on ur dehumidifier this fills up then once full it starts to over flow into the bucket... Seems a strange design but thats how they have done it.
Hope this helps others.
SOURCE: Danby ddr7009ree - continuous drain won't work
I have the same Danby unit and the same problem. When you take out the water bucket look inside and find the two holes where the water drips into the bucket. These holes are approximately 5/16" and 3/8" diameter. These holes need to be plugged. Your local hardware store has an assortment of specialized parts boxes. Find the box that contains "corks" of various sizes. They sell for about 20¢ apiece. I bought 5 within that size catagory and two of them worked! Problem solved.
SOURCE: We have a Frigidaire 70
This happens quite frequently. It''s due to a clog in the hose or the a clog in the hose connection tubing. If you unit has a float valve in the top of the bucket, be sure that it's not stuck in the UP position. To resolve clogging problem, do the following:
1. Turn the Master ON/OFF Switch to OFF and unplug the unit. Disconnect the hose from the unit
and check for clogs and remove them if necessary.
2. If no clogs were found in the hose, the clog is in the hose connection tubing. Use and 18"
long, plastic ZIP Tie, appropriately sized to fit in the hose connector tubing. Carefully insert the
Zip Tie or something similar (NO Wire coat hangers, though) into the hole and continue to push
it in until you reach a bend in the tubing. You will need to gingerly work it past this bend, until
the ZIP Tie either bottoms out or you run out of usable ZIP Tie. Then while rotating (Twisting) the
ZIP Tie slowly pull it out. As you reach the inserted end of the ZIP Tie, be prepared for some
water to follow.
That should solve the problem. Be sure the hose is no longer than 5 feet and that it slopes downward from the unit, with no kinks in it.
Hope this helped you solve the problem. Please let me know, Thanks.
SOURCE: I have a Soleus Air
Several things play a role in the problem you're having.
1. The length of the hose. Shouldn't exceed 5 feet.
2. Is the hose sloping downward from the unit with out any kinks or twists. Most dehumidifiers rely
entirely on gravity to drain the water by hose. It will not drain up and over anything.
3. Is/was there a knockout plug on the dehumidifiers hose connection, that was not removed?
4. Is there a clog in the hose? If so, the water will divert to the bucket.
5. The unit's hose connection or interior tubing is clogged. To solve this problem do the following.
Using an appropriately sized, 18" long, plastic
Zip Tie, carefully insert the tip of Zip Tie into the hose connector hole or tubing.
Continue to push it in until you reach a bend in the tubing. You will
need to gingerly work the Zip Tie past this bend, until it either
bottoms out or you run out of usable Zip Tie. Then slowly pull the Zip
Tie back out while rotating (twisting) it. This will breakup any clogs.
As you reach the inserted end of the Zip Tie, be prepared, as some water
may follow. Reconnect the hose, plug the unit in and turn the Master
ON/OFF Switch to ON. Set the humidity extraction level to 35% or
Maximum if you have a manually controlled unit. Then monitor the hose for water flow.
I hope this helps you to troubleshoot & solve the problem. Thanks for choosing FixYa.
