This problem probably is the Panel faulty. To solve it only changing it for a new one
I'm not sure what you mean by large black shadow, but it may be your screen that is failing. Ask friends for a honest repair person to look t it and tell you what they think the problem is. I wish I could tell you more,m but a large black shadow is not one of the symptoms I ever heard of.
SOURCE: Horizontal (dashed) line across screen
On the KDFE55A20 this sounds like a bad Q-Box. I would get an estimate from a Sony authorized servicer as this part may be quite expensive. On the 55A10 model this may be the B-Block and is also quite expensive. Getting an on-sit estimate would be the first step I suggest. Again go with an authorized Sony servicer. Call Sony or go to Sony.com for customer service. Good Luck
SOURCE: nokia 6820 black screen
you have a damaged screen. they generally go black when they have been cracked and the liquid crystal has leaked. the LCD can be replaced, but if it also has a tired battery, it is probably not worth repair. If you want to replace the display,you need the correct tool to remove the screws from the chassis internally, and the new LCD can be purchased from http://cellink.com.au/products/ They have the tools and parts to repair just about any phone. Good luck. A "fixya" rating for my advice would be great :)
SOURCE: shadows on screen
Try moving a medium powered magnet (not one for picking up heavy objects and not a refrigerator holding one) over the distorted area. If that doesn't work, try a more powerful one. This worked for my Toshiba LCD. Good luck!
SOURCE: my samsung lcd tv is 18 months old and has now
Sounds like burn-in. Yep, LCD TVs can have it too. If you look close, I would bet you will the channels that has the bars down each side line up pretty good with that shadowy line. I have spoken with Samsung about this issue in the past, they will not cover it.
SOURCE: Black line Down middle of 50" plasma screen tv
The tv T-CON board it is dying to causes this problems.This T-CON board sit in the middle at the bottom of the tv plasma screen panel.Try website like Ebay.com to buy a whloe new refurbish T-CON board for the replacement.
