What? That is not a question. I could do better if you ask me to guess what color you are thinking of. Supply more information if you want an actual answer.
May be an issue with the feed dogs, or possibly a burr on the hook. Lay a peice of scrap material under the foot as if you were going to sew, remove needle, then run machine in reverse to see if it feeds material backwards as it should
The feed dog are probably dropped lower than the the throat plate. Most machines have a setting for darning that requires that the feed dog to be dropped below the sewing surface. There is a separate knob to change the feed dog from this lowered position so the feed dog, when the balance wheel is rotated will come up above the sewing surface to move the material. Another thing could be that the stitch length lever is set on "0". This is basically telling your machine not to advance any material through it and you will get a big knot instead
the feed dogs are what pushes on the material from underneath. perhaps they have been lowered ? You do that for free hand or embroidery work,
look for a lever at the back, behind the bobbin area. That's where they are in the janome, which is related to the kenmore somehow; good luck
Depends on the model but some machines have a problem that the feed regulator cam has become loose (2 set screws) and will not advance the material. A good Babylock dealer will be able to diagnose quick.
