I just started 6 weeks ago and I've gotten 2 check for a total of $2,200...this is the best decision I made in a long time! "Thank you for giving me this extraordinary opportunity to make extra money from home. This extra cash has changed my life in so many ways, thank you!"
Visit site: http://Geosalary.com
SOURCE: Play yard assembly COSCO Funsport L-3
for Model Cosco Funs Port Play Yard
Just pull the cord in the middle of the upward and straighten out
each poll one by one. If you have someone that can help you
open the play yard pull lightly up the four sides and while you're holding them up, pulled the middle strip that located inside pull it up it will lock all four sides at the same time.
I don't have childred, but it drove me crazy that I couldn't do this
until my wife said maybe this is how you do it, I tryed it and it worked. I hope this helps everyone. Regards,
Frankie.
SOURCE: How do you disassemble the Cosco Funsport Play
Steps to disassemble.1) Pull up on the loop in the center.2) Flip the Funsport upside down3) Pick a side and pull the corners up slightly while pushing the center down. Sides can only move up about an inch.4) Press the release catch in the center of the bar.5) Pull the center of the bar up while holding the release catch in. Sometimes you have to wiggle the catch in and out to get it to release.6) Repeat for each side.7) After each side is collapsed squeeze everything together.8) Place the cover on the floor black side down.9) Put the Funsport on the cover with the plastic corners flush with the edge of the cover. The wheels should be sticking out the bottom.10) Wrap the cover around the Funsport and secure the velcro straps.
SOURCE: how to fold down the cosco funsport play yard.
There is usually buttons under the cover in the middle of each side? Squeeze this and the side should collapse, then usually a pull up in the middle which reduces the cot right down. Hope it helps
Instructions
1.
Unfasten the floorboard
from the folded play yard frame by loosening the hook and loop tabs holding it
in place.
2.
Unfold the play yard and
set it upright with its four legs on the floor. Pull out on opposite corners to
spread the legs of the frame.
3.
Pull up on the plastic
handle in the center of the floor of the play yard to unlock it fully.
4.
Pull up firmly on the
center of each of the four side rails until they click into place, while
continuing to pull up on the center handle.
5.
Push the center lock
down until it clicks all of the legs into place.
6.
Place the padded
floorboard into the play yard.
7.
Locate the two hook and
loop tabs located on the underside of the floorboard and pull them through the
slots in the bottom of the play yard frame. Secure the tabs underneath the play
yard.
