I will like toowna written :booklet or instruction manual to set time,maintenance,cleaning,etc...my tissot 3000/1853 navigator watch
DON'T SEE BOOK THIS MAY ASSIST YOU.
https://www.youtube.com/watch?v=n0UBaYr6KY4
SOURCE: Setting time & date on Philippe Starck Fossile watch ph1080
hold the left, bottom button (marked ....) for a few seconds....then press the top right button (marked with 1 dot) to change between the hour, minute, date etc. use the bottom right button to advance the flashing number, and when finished setting time and date, use the bottom left button to stop the numbers flashing and return the watch to normal. hope this helps, this is also how to change the date for the other question asker (works on 2 other starck/fossil watches i have and i assume the controls are the same).
SOURCE: need a watch manual or instructions
A-Tech watches are sold under Dakota name. Here is the link for manual (best I could find):
https://dakota.webfeatsecurity.com/PDF_FILES/3sensorpt2%5B1%5D.pdf
Use zoom to get a better view.
Rate me, please.
SOURCE: INSTRUCTIONS FOR SETTING UP A
my pod watch will not restart,it's frozen,also can't find instructions so I can set correct time.
SOURCE: setting instructions
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all COLUMBIA watch manuals.Rate me, please
