I have a coleman powermate 7000 generator (Honda engine). The muffler broke off, leaving part of a bracket and a tube in place. I bought the correct replacement. I now have to remove the old bracket/tube, then install the new muffler. I'm looking for instructions on which tools to use and how to proceed. I have pix but don't see a way to upload them.
Two 8mm nuts hold muffler to exhaust port.
Item 29 in following diagram.
https://www.jackssmallengines.com/jacks-parts-lookup/manufacturer/powermate/generator/pm/pm0435001/generator-parts
THIS LINK MAY HELP
https://www.ereplacementparts.com/powermate-pc0497000-7000-watt-portable-generator-parts-c-117046_130613_327646.html
Testimonial: "Thanks. That's for buying the part, which I already have. There are no instructions. As I said above, I'm looking for instructions on which tools to use and how to proceed."
SOURCE: Brand new Generator not working
Take it back where you bought it with the sales receipt. Just about everything has at least a one year warranty, Anything that's well built should last AT LEAST one or two years. As long as it wasn't submerged, abused or dumped off the tailgate of a truck they should make it right for you.
SOURCE: 2008 Ford Fusion Wing Mirror Replacement
I checked Ford Focus mirror replacement and it seems to be the same. This is for the manual, unheated mirror.
Remove the mirror cover inside the door - slide a screwdriver behind the cover and pry loose carefully.
Remove the single 10mm bolt and the mirror comes free.
NB. Do not drop the bolt into the door.
SOURCE: sparkplug replacement coleman 1850 generator
John if you pull the old plug out the plug number will be on the plug itself it will ahve the manufacture number and manufacture name. Otherwise take it to any parts store and they can match it. Nappa Auto parts will carry it for sure. Be sure to ask them what the gap is on it they will have in in the book but will be .0035 IN. I believe. Be sure to gap it as they are supposed to be gapped alread but some are not even close. Also Nappa will have the reference guide for the briggs and stratton engine but are a real common plug.
SOURCE: I'm looking for an owners manual for a Coleman Powermate 4000
You may not be able to find the owners manual, but if you search using model / type #s off the engine, you may be able to find the manual for the engine from the manufacturer.
