SOURCE: I have 2 clocks (model 40009,40010)that have inaccurate time
I read the manual which said to depress the alarm button. That wasn't the right button but I found that depressing the button next to it, the DST button, that that fixed the problem.
Thanks.
SOURCE: mt atomic clock is always 2 hours slow no matter
How
to Change the Time Zone
Press and hold the “-“ button for 3 seconds the letter P
will appear where the seconds are than press and release the “-“ button until
the correct letter for your time zone appears.
The four time zones are P is Pacific, M is Mountain, C is Central and E
is Eastern Time zone. Press the SET
button to confirm or leave the setting to confirm and exit automatically.
SOURCE: I have an older large wall clock - model 88100. It
If it is a radio controlled clock and it is consistently out, then the hands need re-setting. I have hand a similar experience with my watch, so I fully understand the problem.
You can adjust the hand settings by pressing the right buttons!
If you have the instructions, then refer to the to adjust the hands. If you do not have the instruction, then go to the makers web site and look for manuals download.
SOURCE: Oregon Scientific Model 323a--Atomic clock...the
Make sure that the clock is set for the correct time zone and that the DST (Daylight Saving Time) function is ON. Also, although not mentioned in the manuals, these clocks will typically jump and hour ahead or behind when the batteries get weak. Replace your batteries if they are more than a year old.
Bill B
