Question about Sansui Televison & Video
Please I need help before I buy the original remote to sansui model SLED2490. Can I hook a analog antenna and get local channels without any other hook up to the tv? Please be so kind!
  • Sansui Master
  • 3,150 Answers
Already answered on your earlier post/
Short answer, analog probably not possible.
Maybe if you get a digital antenna and you have stations in your area.
Posted on Nov 03, 2019
6ya staff
SOURCE:
Pookeybrain
Pookeybrain
  • 51 Answers
SOURCE: 1999 sansui tvm1915 tv
You'll most likely need a Sansui remote made to work with your specific model TV. I have similar problems with my Toshiba TV. Check eBay.
Posted on Nov 10, 2007
Anonymous
  • 78 Answers
SOURCE: Sansui SV 2102 GOT SOME PROBLEM PLEASE HELP TO FIND OUT A SOLUTION OR KINDLY INFORM ABOUT THE SANSUI HELP NO.
on some tv's you can get to the menu by pushing both the channel up and down buttons at the same time.
Posted on May 05, 2008
Anonymous
SOURCE: Can't get one local channel when hooked up to T.V. antenna
Take a gun and shoot your self.
Posted on Feb 19, 2009
Anonymous
  • 5 Answers
SOURCE: I own a Sansui model
You can download the manual from Orion who makes Sansui.
http://www.orionsalesinc.com/Downloads/27-/View-category
Posted on Feb 23, 2009
Chi Chu
  • 8457 Answers
SOURCE: Need 1992 Remote Control For RCA ColorTrak TV Set
Tries 1-800-Factory remotes originals Website.
U get same as the original remote.
Posted on Aug 17, 2009
Lost remote for sansui sled2490 how do I do channel scan
Without a remote control, you can't. If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand. They can either give you a genuine remote control to your device, or can direct you, from where can you purchase a suitable one.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability. Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device brand you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its pack. Never accept a remote control, that hasn't both of this. For more details about the set-up codes, visit the sites.
http://homenol.blogspot.com/
http://electrohelponline.blogspot.com/
http://remotesearch.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops. Visit some on-line sites too, which deals with electronic spare parts.
Mar 14, 2017 | Sansui Televison & Video
I'm trying to hook up a 19" Sansui tv. I'm not on cable, but tried hooking it up to an antenna without any luck. What do I need to do to get the TV to work???
Make sure the TV can receive digital over the air signals (it should have an ATSC tuner), that is it doesn't need a digital converter box. In the menu settings make sure the TV is set to antenna, not cable. You should be able to use the auto-scan (auto-program, etc.) from the menu to find and program the local channels.
Feb 02, 2016 | Sansui Televison & Video
How do we scan/program in local tv channels. We bought an external antenna, but get no picture. Typically, there is a protocol for scanning channels into the set. Model is Sansui TVS2746B, and the set was...
Okay, does this tv have a built in DIGITAL tuner? Most tv's only have an analog tuner. You can tell the difference while you are changing the channels. If the channel indicates 2.1 or 2.2 and so forth, it is on a digital channel mode. If you change the channel and it indicated 2, 3, 4, etc. it is analog. If it has digital capability change the input until you see 2.1, 3.4 etc. If you cycle through all the inputs on the tv like, input 1 (TV) input 2(DVD) input 3(HDMI) and so forth and you never see the digital channel you most likely do not have a digital tuner. You will need to purchase a digital converter which will convert it to analog and you can watch it by placing you tv on analog channel 3 just like the old vcr's. Hope this helps and please don't forget to rate this solution.
Jan 22, 2011 | Samsung TSL2793HF 27" TV
Sansui old model TV SV2110K get locked 3 channels and original remote lost. Now I want to clear the lock. and some channels are not showing now a days. pls advice....
Use the buttons on your TV and go through the menu and do the same thing as you did when you had your remote. If some of the channels are not showing you will probably need what is called a digital box or receiver that you can buy from your Local WAL-MART
Aug 05, 2010 | Sansui Televison & Video
Trouble getting digital on a sansui 27"
your antenna is not strong enough to receive
digital or your in a area where large
structures are blocking the reception.
you could try turning the antenna slightly
and rescanning .
Jun 12, 2009 | Sansui DTV2760 27" TV
Switching singnal
If you are using an antenna or regular cable without a cable box, put the tv on an analog channel. Go into the menu. Select the middle icon at the top of the screen. Go down to the TV/CABLE line. Select either TV (for antenna) or CABLE (for regular cable) on the right. Go down to AUTO CH MEMORY and press the volume+ (right arrow) button. Wait for the channel search screen to clear. Check all of your channels using the channel up button until you come back to the channel you started on.
Feb 28, 2009 | Sansui 27" TV
Sansui HDLCD1908 not recieveing Digital channels
Go into the menu. Go to CHANNEL and press enter. Go to AUTO CH MEMORY and press enter. Press the right arrow on remote to change the signal type to AIR. Go down to AUTOMATIC SEARCH and press enter. Wait for it to finish on its own. You should have all the analog and digital channels you can get with the antenna setup you have connected to the tv.
Jan 06, 2009 | Sansui 19 in. LCD TV
Sansui 27 inch # DTV2798
Yes. It takes a while to scan for all the channels.
Jul 09, 2008 | Sansui Televison & Video
Nov 10, 2007 | SansuiM1315 TV
Televison & Video Logo
20 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
