Just installed A/C unit on my camper. it is a ducted system I got the thermostat and the multiples zone controller. I am getting no power to the thermostat.
SOURCE: Tech said that the Carrier equipment controller
normally when the zone board is bad you only have to replace the zone board, thermostats should still be o.k.
SOURCE: Zone cooling not delivering adequate air to both zones simultaneo
You need to have someone evaluate the ductwork for the home. With all zones calling, there should be an even balance of airflow. And when only one zone is calling, there should not be the tornado effect you describe.
The dampers feeding each zone may be of the wrong size. It also sounds as though you are also having a problem with your bypass damper. This damper is designed to bypass excess air when only one zone is calling. It is operated typically off the airflow alone.
Have it check out. You definitely have a problem. I would recommend getting it looked at by a company other than the installing company to remove any bias judgment or diagnosis.
