If you're moving your grandfather clock by yourself, use a dolly to take the carefully packed timepiece out of your home and to the moving vehicle. Tilt the box as little as possible when loading it on the truck. Use straps to secure the clock case, so that it won't slide, slip or tumble down during the transportation.
If you are not sure how to transport a grandfather clock, you'd better keep it in an upright position during transit. Newer grandfather clocks can be moved lying down but this puts unnecessary pressure on the panels and glass elements, increasing the risk of breaking. Older clocks need to be moved upright because of the weight of the movement and the way it is attached to the case.
Do you want the hottest new Apple Watch?
Collect 100 Points and get an apple watch now. New offer for United States Only.
Copy this gg.gg/an-Apple-Watch-Now and past in your browser.
SOURCE: hi i'll try to make this short,i have a
After reading all the explanations I understand that your clock is not overwound or damaged and do not need any further repairs even you've been transporting (carrying) it.
The reason it does not work is simple - your clock is out of beat and all it needs is just to put it back in beat. This is simple operation for watch/clock repairer, but would be very difficult for you without proper knowledge.
So, my advice is: Take your clock back to that repair shop (don't forget the receipt for the previous job done). You must carry the clock with the pendulum off, but don't leave it at home. When in shop, ask to put the clock in beat. Simply say: '' My clock is out of beat. Can you correct this for me, please?''
As this clock was repaired there some time ago (receipt is proof), this is clockmakers responsibility to put it in beat before handling back to the customer. As well as this, clockmaker should have to explain how to carry the clock and how to hook up the pendulum without disturbing the escapement. If it was not done, you have the rights to ask to fix all that.
Do not be afraid to go and to ask them to finish their job properly. These are your consumer rights and you are not asking for any extra work to be done.
Do not try to contact them over the phone, as it is allways better to face the person and speek directly.
Pull your socks up and go!
Good luck.
Rate me, please.
SOURCE: the clock time cannot be set on a
You question is a bit non descriptive except that the clock does not work and the hand clutch has failed.
GOTO:
http://www.nawcc.org/business-directory/
Hopefully this will guide you in the correct direction for a local repair person.
Hope this tip helps
R/
David
SOURCE: I have a 1983 reproduction
Hi Petah 920...I have also aquired the same clock, with the pendulum and other parts missing. I intend to fabricate the missing parts ( I am a clockmaker) and engineer. My problem is not knowing the exact parts, I have contacted Thwaites
SOURCE: we have a seth thomas
The clock must be levelled the same as when it was previously set up. In other words, if you didn't check the level of the clock before disassembly and reassembled it and re-levelled it, it may not operate because it might not be the same.
Some clocks have different weights for the clock, chime, and hour strike. Did you mark them and install them in the same location?
My Seth Thomas has a screw to adjust the swing of the pendulum to allow proper escapement on the gear, but you have to be able to determine which way the pendulum needs to swing more to make that adjustment. I may be able to help you with this!
You may need a clock repair service.
Let me know,
Gary
SOURCE: pendulum will not stay swinging on mantle clock
check out the link below
http://www.youtube.com/watch?v=ps6dPxoxe9c
