SOURCE: wireless internet access
A wireless 802.11b LAN adapter is included in you tablet, activate it thru Control Panel / Wireless. Unfortunately this is the first generation standard and as such is extremely slow, has very limited range and is no longer supported by a lot of the newer generation devices/hotpoints.
SOURCE: My ACER tablet (ICONIA
Welcome to Fixya. I would like to know if the wifi works before? If the laptop was able to detect and connect to a wireless signal and the Iconia won't you can check the warranty of the Iconia and call acer and they will be able to replace the unit. This is a common issue with Iconia that some of the device has a hardware wifi defect. You can also refer to the link below and see what happen with their Iconia and was able to talk to acer for a replacement.
Iconia Forum
Thanks
SOURCE: how do i set up wi fi
Just open your tablet's wifi function, at the same time, open your home's wireless network, then use tablet to search for home wireless, and get connected if it's found.
Android 4.0 Tablet PC
SOURCE: I don't have internet connection on my my new asus tablet
Read and look at the diagrams on the following link. It should help you a lot.
Read this:
http://www.wikihow.com/Find-Your-WEP-Code
SOURCE: I have the digiland tablet dl700d(c) and I can't
Yes, Mike is right...MAC address do not change...maybe its the IP address...but then most of us including me have a dynamic Ip which keeps changing...but I do not have any problem in connecting through WiFi. Try switching OFF and ON the modem or upgrade to latest version...if nothing works...you can also opt for a static IP from the ISP.You can check in for the current IP in IP-details.com
