Question about Samsung Televison & Video
Hi my Samsung tv is about 10 yrs old. model #L4NOC530FIF. Is it an HD TV? Can I upgrade my digital box to HD?
6ya staff
SOURCE:
tom19511
Thomas Christopher
  • 1601 Answers
SOURCE: VIsta Media Center and Comcast Digital
nechmads,
The s video connection is not a digital signal, it is analog.
This should help you get what you need to set it up.
http://www.microsoft.com/windowsxp/using/mce/expert/hdtv.mspx
Posted on Feb 18, 2008
Anonymous
  • 38 Answers
SOURCE: SAMSUNG LCD TV horizontal lines
causing of horizontal lines is leaky or defective capacitors. check big value capacitors around the board at Horizontal area. check the filter capacitor as well. good luck
Posted on Apr 20, 2008
Anonymous
  • 476 Answers
SOURCE: probem getting sky to work with a new TV
An HD TV connects in the same way as a standard TV.
Connect a scart lead from the TV scart of the Sky box to the TV.
When you switch on the Sky box it should automatically switch the TV to the correct external input.
Posted on May 20, 2008
Anonymous
SOURCE: Akai tv remotes
I purchased a HARMONY remote ( logitech ) and it worked for the AKAI PDP4273M .
Posted on Mar 16, 2009
jason
  • 905 Answers
SOURCE: is my tv a jvc model HD-61Z456 ready for digital switch
yes it is digital ready , just follow the guide here for setup of digital mode http://www.fixya.com/support/p520408-jvc_hd_61z456_television/manual-32932/page-33
Posted on Mar 21, 2009
I have a Sony Bravia led digital kdl32m4000 tv, I am upgrading my satellite box to hd will I get the signal in hi def. or do I need to upgrade my tv?
No you don't need a new tv. Hook up your HD cable box using HDMI cable. Hdmi out on your cable box then hdmi in on your tv. You need your tv remote to change source input to hdmi.
Jun 10, 2017 | Sony Televison & Video
RE:Samsung Model #TCD1341, Manufact./Aug.1995, digital-capable?
No it does not have a HD tuner. The simle way is a Digital Converter box for about $40.00 it will have composit out (red, white and yellow leads) plug these into TV you will have a converted Digital signal that will make your old set
look like a HD set.
Nov 08, 2009 | Samsung TCD1341 TV
I have a samsung tv and dvd player and it has just started coming up on screen when i load a dvd to play a region error messagesayinh no good.It has been working ok before this.i just recently upgraded my...
make sure your tv is set in right language and location because after the big re-tune you might of entered wrong ones
the best way to do this is reset back to plug & play put tv in analog mode press TV/DTV on remote and then MENU ( NOT DTV MENU ) move down until you see plug & play in one of the menues press enter and follow on screen instructions
Nov 07, 2009 | Samsung LE32R72BX 32 in. HD-Ready LCD TV
Samsung plasma hd ps42097
I think it is the software checking for an update.
I also have a Samsung plasma.
Go to Menu- Support- Software Upgrade- Standby Mode Upgrade.
It is generally set frequently (mine was every 45mins) so I just changed it to 0:00 so it 'clicks' only once at midnight to do the software check.
Hope this helps.
May 27, 2009 | Samsung PPM42S3 42 in. Plasma Television
Hi-Def?
Yes, it is HD TV ready but you must have a set top box from your cable or dish company that provides a Hi Def signal. The inputs must also be connected with the YRB cable. Only certain channels on my box are HD. The screen is so large that HD isn't nearly as impressive as some of the smaller models but it is still HD. I also have the 53FDX10B.
Mar 03, 2009 | Hitachi 53FDX01B 53" Rear Projection...
TV won't turn on after cable outage
No your set would not be like the HD52W19 model ,your model number is on back of tv year,chassis & Model # being 10 yrs old ptk195 model------- older Rca ptk169 these sets are 16yrs old.My guess without hands on chassis Bad Flyback Transfomer.
Dec 02, 2008 | RCA D52W19 52" Rear Projection Television
Panasonic TV -7 to 10 years old (I do not have the manuel to this t.v.)- 19
That year of TV will most likely not have a digital tuner. You can still use the TV with a digital converter box as long as you are getting your reception over the air with an antenna.
Jul 24, 2008 | Televison & Video
Probem getting sky to work with a new TV
May 19, 2008 | Televison & Video
Televison & Video Logo
23 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
