Televison & Video Logo
A
Anonymous Posted on Nov 04, 2019
What is wrong with my 50 vizio tv as it does not turn on when I press the start button on the side of the tv?
Model # E480i-B2
Ruffa bonos
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 18 Answers
  • Posted on Mar 27, 2020
Ruffa bonos
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
18
Questions
0
Helped
5490
Points
37
If the television still won't turn on, turn your TV off at the wall and unplug it from the plug socket. Wait 30 seconds, and then plug it back in and switch it on. This is called a 'soft reset', and should recalibrate the TV.
Redacted
Level 2:
Habit-Forming:
  • Expert 91 Answers
Redacted
Expert
Level 2:
Habit-Forming:
Answers
91
Questions
0
Helped
35126
Points
223
Make sure your TV is plugged in and then try turning on your TV using the remote.
5 Related Answers
Slinteriors
Sonny Berry
  • 8617 Answers
  • Posted on Apr 04, 2008
SOURCE: I have a mitsubishi 50
That model has a problem with the CRTs dripping fluid onto the oards directly under the tubes and it will corrode the components and solder preventing start up. Check the boards for evidence of coolant leaking it should be either wet shiny or a pasty residule if so let me know and I will try to help you straighten it out.
Anonymous
  • 3 Answers
  • Posted on Apr 05, 2008
SOURCE: TV Will Not Start Occasionally
I was having same problem, then on 4/4/08 it went out with just a blue screen, with no signal, then it would turn itself off in about 4 seconds! Not to happy here! its 3 months out of warranty so no help from vizio. my buddy had the same problem a month or so ago with same tv GV42L HDTV. if your handy you could do it yourself, like i will when part gets in. saving some money! its the main board ***'y you can look it up at vancebaldwin or shopjimmy.com. i would just keep using until the screen goes blue. Hope this helps
Anonymous
  • Posted on Aug 04, 2008
SOURCE: remote code for Goldstar VC681M to match Vizio VP-50 remote
Try 747; it's supposed to work on most combomodels
Anthony Gonzales
  • 267 Answers
  • Posted on Feb 06, 2009
SOURCE: 46" LCQ VIZIO WON'T TURN ON ALL OF A SUDDED
IT SHOULD BE UNDER WARRANTY. TAKE IT TO AN AUTHORIZED VIZIO SERVICER.
Anonymous
  • 56 Answers
  • Posted on Feb 16, 2009
For the 46" TV, it sounds like the main board is bad.
For the 50" Vizio: is the LED light on?
2answers
TV stopped working, need to know which part to replace?
I would check you power supply and internal fuses. But most modern electronics are not fixable just a FYI.
My vizio tv won't shut off and it will not work on any of the smart functions? I unplugged and left overnight and it did not help it. It is only 3 years old.
The board where the power button is located is probably bad. The power button itself will be part of that board, which will also have the other controllers (i.e. "all on one board"), which would explain your multiple problems.
Vizio TV has sound but no picture
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
How can I fix ? where do I get parts ?
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Best picture setting for vizio E480I
Go to the main menu and find settings. You can set the default screen parameters there.
Keep in mind that there are still channels which are not yet providing HiDef video to carriers,
Where is the serial # located on the vizio hd smart tv
It can be noted at the back cover of the TV; or at its chassis inside.
Electro help
VIZIO TV SAYS INCORRECT CARD
IF YOU HAVE CABLE CARD FROM COMCAST OR OTHER CABLE COMPANY CALL THEM AND LET THEN THE CARD IS BAD Colorvision Services
Top Vizio Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
