Question about Maytag Epic Z 6.7 cu. ft. Electric Dryer
Its making noise and holding water won't spin and all my control lights are on and the digital panel code is F12 is popping off and on its a Maytag Epic Z
    Top Expert:
  • Maytag Master
  • 10,402 Answers
Check under agitator for broken cog or belt under unit
Posted on Nov 13, 2019
6ya staff
SOURCE:
Anonymous
  • 141 Answers
SOURCE: Maytag washer. Model PAV1000AWW: It
If the motor is spinning fast, but the tub is not spinning, then it is the transmission. If the motor is not spinning, then the high speed windings of the motor are shot and it needs a new motor.
Posted on Sep 06, 2008
prem mathew
  • 1294 Answers
SOURCE: Maytag epic he has F6 code
First empty as much water you can thru the front door. There is the filter located right before the water exit pump. Remove the lower panel by unscrewing 3 screws underneath the panel, slide the panel out. You will see a 3 inch cap facing you. Either you must have a shop wet vac or a nice big plastic bag to collect the water which will leak out, there could be plenty. Clean out the filter, you may find coins too. You can pour some clean water into open machine to wash out the hoses. Replace the filter cap carefully, cover,screws.
You can rate me............
Posted on Mar 06, 2009
Anonymous
  • 235 Answers
SOURCE: makes a horrible noise when spinning out
Changing the belt should help.
Posted on Jul 02, 2009
TomZS
  • 220 Answers
SOURCE: All display panel lights are blinking,
Bad main control sits on the back of the refrigerator about half way up on the left metal cover. Part number 12920710 double check against model before buying runs $170.
Posted on Sep 24, 2009
MARLON KELLER
  • 111 Answers
SOURCE: how to remove the front panel of a maytag epic z dryer
If your unit is not drying well or slow dry it is being caused by poor external venting rather than internally. first make sure you are not crushing the vent hose behind unit then next clean venting in wall and make sure outside flaps are opening and closing properly before opening up dryer. Easy way to tell if it the machine or venting is to take vent hose off and connect a pair of sheer pantyhose to exhaust port on back of dryer and run a few loads if all works well your issue is in the wall not the machine
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on Apr 17, 2012
My maytag mtw5600tq1 washer won't hold water. Its
Its sounds like you have a siphon going on, this happens when the drain hose it too low during fill and as the water enters the unit it exits through the drain hose. To stop this the drain hose needs to be higher than the tub itself, meaning: raise the drain hose behind the washer to about control panel area. This will or should stop the siphon effect and allow the water to remain in the tub. If the drain hose is low this siphon will start again.
I hope this helps
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 26, 2011 | Maytag Washing Machines
Neptune Washing Machine (MLE200AWW) spins but water is not pumped all the way out. I can hear it slosh in the drum if I spin the drum manually.
Hi, the sloshing sound is normal because of the balance ring which has liquid in it...
I would be concerned about your door latch wax motor ( part # 12002535) though... See Neptune Help for more information about replacing the faulty wax motor with brown colored actuator tip before it damages your machine control board. When the wax motor shorts out it will blow the Q6 triac and then the R11 resistor will burn and your door probably won't lock anymore as indicated by the door locked light not coming on. The next thing you will notice is that your clothes will be soaking wet after the wash cycle because the spin cycle will not work if the door does not lock...
Your machine control board is located above the dryer on the right side.
Every Maytag Neptune front loader with a timer knob (non digital) has a wax motor and all of them shipped with faulty one except the later 2000 series stacker models. You should proactively replace the wax motor with the new design (with black tip) to prevent the Q6 R11 failure on the control board. If you're too late you can try the STAGE 1 repair kit at the same site above.
To inspect your door latch wax motor on the stackers you:
? Unplug machine
? Remove the (2) screws holding center panel and remove panel
? Remove the (1) center screw holding the top panel located inside compartment above washer
? Remove the top panel to expose the door latch assembly
I hope this helps you.
Apr 25, 2011 | Maytag Neptune MLE2000A Front Load Stacked...
I started a load of wash and the water stopped flowing into the machine. It will spin, so it isn't anything electrical. The water will not fill it up?
If there's no water at all, make these checks: If you have a Maytag® washer, is the fuse (if there is one) in the control panel at the lid-switch bracket blown? Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 06, 2011 | Maytag Washing Machines
The agitator or drum will not activate. Water pumps out, ok fills ok strange whirring noise when agitator is due to start. no Agitation , no spinning. Whirlpool gold 3rgsc945
YOU MOST LIKELY HAVE A BROKEN MOTOR COUPLING. Remove the screws holding the control panel,(can be in front or back on the end caps) newer models you need to slide a putty knife under the front edges to release the clip.The control panel will come forward then flip up. Next use a screwdriver to pop out the spring clamps that hold the cabinet onto the frame. They are about 3/4 of an inch wide and about 3 inches from each side. Disconnect the lid switch. Now you can tilt the cabinet away from the back of the machine, while tilting the bottom front of the cabinet will slide out and the cabinet can be set aside. now you will have access to the motor etc. Release the clamps holding the pump onto the motor. Now you should see two screws that hold the motor clamps, one above and one below the motor shaft, remove those. Use a flat blade screwdriver to pop off the clamps holding the motor. pull motor out to expose coupling. Make sure to use part # 285753A. repair sould take 10 minutes.
Feb 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Maytag stacked washer/dryer fills with water, makes noise like it's working, but won't agitate, but at the end of it's cycle pumps out but won't spin either. Is this a belt problem? If so how hard is it to...
Definately sounds like the belt is off. Not too big of a problem for small hands mechanics. Usual problem lately with Maytag is the spindle pulley. For some reason they haven't been tightened properly and the pulley and belts are falling off. Pull it out from the wall remove the panel and see what you've got, really simple on the bottom end. Complicated stuff is up in the control panel. Make sure you get the pulleys lined up as close to level as you can or the belt will jump off on you during spin cycles. Good Luck!
May 10, 2009 | Maytag LSE7806A Top Load Stacked...
Doesnt agitate and there is a gronding noise during wash and spin
A common problem with noises from washing machines has been the under wire that may come out of small clothes. In the washer they can get stuck in one of the inner basket holes and make a scrapping noise, they can actually make there way into the pump and jam the pump, or make a terrible noise when the pump is running. Grab a flash light and have a peek inside the washer for this. Front load washers seem very common to this happen! If the tiny cloth  is showing signs of fraying, may be best not to wash it in the washing machine, replace the cloth.
Maytag Dependable care washer.....Locate a 1/4 inch screw on the side of the agitator, ( about 3/4 of the way down) remove this screw and lift up on the agitator...picture.
Maytag Atlantis, Norge, Performa by Maytag.....Remove the cap and softener dispenser by pulling it off and locate the agitator bolt, remove bolt and lift up on the agitator...picture.
Water level controls - The water level control is also know as a pressure switch, this is where you set the water level ( small - medium - large ). The water level control is responsible to shut off the power to the fill valve and direct that power to the timer so the washing machine can start up. The WLC has electrical contacts in it that sends power to the fill valve and when the WLC is satisfied the water level is correct the electrical contacts open power to the fill valve and send the power to the timer and the washer starts. Picture of this here. How the water level control knows when it is time to shut the water off is, a air tight hose runs from the outer washer tank to the water level control. As the water fills the outer tank air is pushed up the hose, depending on which setting you have made ( small- medium - large ) is takes a certain amount of this pressure to make the WLC cycle over and shut off the water and send this power to the timer. If this hose develops a leak or a pin hole the washer can over fill as the WLC may not be able to shut the water off. The water level control can also break down and allow the washer to over fill as well.
Testing a  water level control or a fill valve can be done by using a Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter. Testing a  water level control or a fill valve can be done by using a ohm meter or a volt meter.
A couple of tips from readers (Thankx!! ):
~ If you have a loose hose on the water level control or tank end, use a plastic wire tie to help hold the hose tighter and make a tight fit.
~ The water level tube (tube that runs from the square box), access panel on the outer drum where the bleach tube also ends) from the pressure sensor switch (front panel) can become clogged.  Or the two holes from the outer tub into this square box panel on the outside of the outer tub can become clogged. Either clog, I am told by my help repair guy can cause the sensor to think that there is still too much water in the tub and so will not allow motor to activate spin.
~ If the water level control contact is bad, it may also stop the filling ok, but not tell the washer to start agitating.
Nov 14, 2008 | Maytag PAV2300 Top Load Washer
Maytag Washer Noise While Spinning
Most washer models have snap-clips holding the front of the top panel down, with hinge-like clips at the back. Carefully pry up the top panel on the front of the machine using a tool that won't scratch the finish, such as a plastic or wooden wedge. If it does not pop loose fairly easily, then carefully examine the back of the machine to see if this is a rare model that has screws holding down the top panel. (But really, it _should_ just pop loose.) Once the top panel is tilted up to expose the inside, you should be able to see everything you need to see inside the body to evaluate a spinning drum problem.
Aug 04, 2007 | Maytag MAT13MN Top Load Washer
Maytag Epic Z 6.7 cu. ft. Electric Dryer Logo
35 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
