I love new gadgets and advance technology that makes our life easy. I work at Amazon and write reviews about new gadgets after collecting buyers' comments and making complete analysis by testing those gadgets myself. https://powerator.co/
SOURCE: 92 cherokee sport. Sometimes starts fine,
Sounds like that starter is on it's way out the door. I suggest you change it before it leaves you somewhere.
SOURCE: traeger junior 2 weeks old dosen't seem to make
Take and unplug your electrical cord and then take the bottom grate that covers your motors and components off. The are 4 small screws and then it should drop down. Look to see that there are not any wires hitting your fan motors. You can just reach up there and move them around if they are. Some Treagers seem to have some noise until you use them a little. They have a 3 year warrenty, so if the wires are not hitting the fan blades, I would use it and see what happens.
SOURCE: I have an electric Traeger grill. I plug it in
Make sure your grill is unplugged. Them take the controler out and there is a fuse on the back side of the control. There is also a new fuse there to replace the old one. If the fuse is blown, you could have a bad hot rod or other component that is bad. Usually the hot rod is the problem and they should be under warrenty so call Treager and get a new one sent. If the fuse blows after it is replace, you can un hook the purple wire and replace the fuse and see if it will work them. If it does, it is the hotrod.
