Question about Fisher and Paykel Washing Machines
My fisher and paykel washing machine throws water onto the lid and surrounding area during spin cycle which leaks onto the floor.
6ya staff
SOURCE:
Anonymous
  • 96 Answers
SOURCE: washing machine
If water is leaking only during the times when it is supposed to be coming in , then the first places to check are at the hose connections and the hoses themselves. If it continues to leak after the water stops coming in , then you have to look at the drain connection and finally at the drum seal.
Posted on Feb 26, 2008
Anonymous
  • 7 Answers
SOURCE: water leaking out of washing machine Fisher Paykel
Hose has popped off or loose. Take the back off and watch it fill. You should be able to see where it's coming from.
Posted on Mar 08, 2008
Anonymous
  • 145 Answers
SOURCE: Fisher Paykel washing machine model # GWL15 drips
Hi Dale..
It sounds like you have a leaky inlet valve assembly. The part number is 421029P and is easy to replace. You can get one here:
http://www.fisherpaykelparts.net/ecart/item.php?item_id=266&category_id=56
Posted on Apr 20, 2009
bozcro
bozcro
  • 867 Answers
SOURCE: Fisher Paykel Ecosmart washing machine spills water.
sometimes too much detergent, or extra cleaners like oxy clean) will cause lots of foam which will cause the water level sensor to misread, or foam over the top of the drum. if this is not the problem, you will have to tilt the machine on its side and look for loose or damaged hoses. the play in the tub will not cause leaking
Posted on Jul 10, 2009
Anonymous
  • 3 Answers
SOURCE: Fisher Paykel GWL11 water leaks from lid during final spin cycle
is the machine level
Posted on Oct 09, 2009
During spin cycle water on floor from outside
SEAL IS MOST LIKELY LEAKING BETWEEN AGITATOR AND DRUM, SEALS ARE CHEAP AND DEDERGENTS OVER TIME CAN WEAR THEM OUT.
May 25, 2010 | Fisher and Paykel GWL11 Top Load Washer
Puddling on floor during high speed spin cycle
you have a leak in your outlet hose normally caused by rubbing on the drum barrel / repair with tape or replace whole hose but this brand of wASHER ITS VERY HARD TO REPLACE IF DONT KNOW HOW TO
Apr 27, 2010 | Fisher and Paykel GWL11 Top Load Washer
I have a fisher paykel eco which is spining water on the floor.
You could take the pump out and check it for obstacles
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Mar 05, 2010 | Washing Machines
Jul 10, 2009 | Washing Machines
I have a 1.5 yr old Fisher Paykel ecosmart washing machine. During the past 2 loads there has been a notable water leak (significant puddling on the floor). I haven't witnessed the problem, but there is...
the play in the tub in normal, it sounds like you have an over sudsing issue, run an empty load with 3 cups of vinager in the tub, set the water temp to hot, cut way down on soap, if you use liquid dont even fill the cup 1/3 of the way, I know this sounds dumb but try it, I have one and this happened to me
Jul 10, 2009 | Fisher and Paykel Washing Machines
Water leaking from top
That's an easy one... There is something caught in your diverter valve, keeping it partly open in spin, so that when the water is supposed to be draining out the drain hose, some of it is gettng back up to the recirculator hose, spilling onto the spining tub and then out onto the floor...
Nov 17, 2008 | Fisher Paykel EcoSmart GWL15
GWL11 Machine adds water during spin cycle and leaks on floor
diverter valve is not switching to pump the water out. instead it is resurculating back into the tub.
Oct 14, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
67 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
peter gittos
peter gittos
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
