SOURCE: troubleshooting sony handy ccd-trv 107e
The first thing you should try is removing the batteries for 20 to 30 minutes to reset the unit. If this does not work push in on the cassette mechanism at the top while trying to eject. Also check the tape compartment cover screws to make sure they are tight. Any misalignment in the cover mechanism will cause binding which will create the problem you describe. Finally, and I know this will sound unusual, slap the unit on the cassette side. Forcefully but not enough to break anything. This procedure has been helpful many times with similar problems. I know it is not sientific but hey if it works. If none of the procedures solves your problems you may need professional help. The following websites offer free estimates: http://www.camcorderrepair.com or http://www.videotech.com or http://www.videoonerepair.com Good luck
SOURCE: sony ccd-fx310
My camera won't play back. Occasionally, if I ffwd it will show the picture otherwise its a blank screen. Any ideas? I've tried cleaning the heads a few times now
SOURCE: sony hi8 ccd-trv208e pal camcorder
Same problem, same frustration. Just flashing, won't open to insert tape, Battery relatively new. Is there any way to get it to open to put in tape? I hate this technology, not along far enough.
SOURCE: Sony Handycam CCD-TRV37 Error code C:32:20
1. I removed the battery. 2. With the power switch On position and holding the tape ejected I inserted the battery back on & it ejected the stuck tape.
SOURCE: VCR tape is stuck - will not rewind or eject.
There schould be a release buuton on the rear of the machine. It's usually recessed and may be difficult to see. Press this with the yip if a ballpoint pen and extract the tape. If the tape is wrapped around the record/playback heads your only option is to remove the top cover and manually remove the tape. Sounds difficult but if you take your time it's not too bad a job.
Testimonial: "Thank you! - no button - took the top off. I depressed a lever next to the tape switched the VCR back on and pressed the eject button - it worked!"
