Question about Westinghouse Televison & Video
My Westinghouse WE58UL4218 LED TV has stopped responding to my remotes, (either the TV or Cable).
For a few weeks it has displayed a grey snow screen alternating every few seconds with a black screen for as much as 30 seconds before coming on completely.
6ya staff
SOURCE:
Anonymous
SOURCE: TV shuts down
Remove the lamp assembly, There will be a screen on the top and bottom of the assy remove all dust from these screens. also check the tube at the top of of the lamp receptical this is an air cooling pathway. reassemble and fire it up. This worked for me and saved some serious coin judging from some of the other solutions I have seen (lamp and balast) ouch!!!
Posted on Jul 06, 2007
Anonymous
  • 16 Answers
SOURCE: black/GREY screen with light spots screen
Try reinstalling the gpu driver. If the problem still persists, the screen may be going out.
Posted on Apr 17, 2008
Ajkill
Anand Kumar
  • 2035 Answers
SOURCE: Westinghouse Green Screen
You can also try a hard reset: Unplug TV from AC mains and remove all cables from TV. Wait about 30 minutes and replug to AC power and redo the cabling. Switch on the TV and see if it works..
Posted on Jun 10, 2008
Anonymous
SOURCE: Mitsubishi VS-6071 60" Rear Projection TV Problem
can you give me the number of the manufacture of a 60in mitsubishi VS-60707
Posted on Nov 17, 2008
rustym62
Rusty Morales
  • 201 Answers
SOURCE: I have a similar problem with the Sony 60
I believe 4 blinks is fan error. You can take back off and watch fans in particular the fan for the lamp (this one goes out the most) The TV has a sensor so it knows if the fan turns.You can take a pencil and use it to spin fan sometimes that will jump start it (not a permanent fix just a test). You can try cleaning dust off fan and replugging the connector on the wires coming from fan.Might fix it if not fan will need replacement.
Posted on Apr 28, 2009
Vertical color lines wont stop running while audio is good.
Westinghouse SK-32H240S Problems Anyone? - AVS Forum ' Home ...
www.avsforum.com/.../1143881-westinghouse-sk-32h240s-problems-an...
May 2, 2009 - 30 posts - ‎18 authors
I have owned my Westinghouse SK-32H240s for about 18 months now, and I ... Youwon't be certain if you are getting the right firmware or the complete firmware. .....makes it stop for a while, the same as it may with a weak antenna signal. .... would just go nuts and display a bunch of colored bars vertically.
Roku Forums • View topic - Westinghouse LTV-32W1 HDMI problems
forums.roku.com/viewtopic.php?f=28&t=27628
Apr 28, 2010 - 15 posts - ‎8 authors
I have a Roku HD box and a Westinghouse LTV-32W1 tv. ... Any idea on why it won'tconnect to the roku correctly? ... This does nothing to stop evil people from stealing movies, but does make ... but it is just a bunch of lines and colors all stretched every way. .... all running wireless on a actiontec C2000A.
Westinghouse LED TV LD-4655VX Fix - YouTube
? 24:48
https://www.youtube.com/watch?v=N_zPWgEitjE
Aug 7, 2013 - Uploaded by TipsNNTricks
Your Westinghouse TV Parts Here: http://amzn.to/14ETOTN ...LED LCD TV FIX, How To For Samsung Double Image, BlackVertical Lines, Screen ... Samsung TV Won't Turn On - How to Repair Bulging Capacitor for ... Problem with Westinghouse LTV-32W6 - Duration: 5:09. by toddalex4 20,284 views.
Dec 19, 2015 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How do i get cable tv on my westinghouse tv
Go to the menu look for the input settings make sure it is set for cable not air. There might be a input button on the side of tv or on remote that will let you select which input to use. It will have to be set on cable thin scan for channels.
Aug 08, 2017 | Westinghouse 32-inch Led-lcd Tv - 720p...
My Westinghouse TV was working just fine, but stopped turning on after I had issues with the cable box. Those are resolved, but I can't get it to turn on. Anyone have any ideas on how to fix this?
Patience may be the key--It may be substrate charge phenomenon--
Disconnect everything from the TV, including power cord and all ins & outs and wait awhile (3 days is sufficient) to let the internal charges bleed off. Reconnect TV and try it again. It sounds like a power surge (or lightning strike nearby) jammed a temporary "substrate charge" onto TV's circuitry.
May 05, 2015 | Westinghouse Televison & Video
I have a westinghouse LED 40in TV I was watching TV and my finger hit a button on my cable remote, usually I have to get the TV remote and press HTML1 now my TV has a purple box I tried everything and cant...
if that purple box is in the center of the screen you have hit closed caption, you just need to locate that in either TV menu or cable menu & turn it off
Apr 30, 2014 | Westinghouse Televison & Video
The image display on my Westinghouse 42" LED TV does not fit the screen. It is zoomed in, so when watching sports, i cannot see the score and time ticker.
Using the remote go to the menu for the TV. Look for picture or aspect ratio. Make sure it is set to 16:9 and not zoom or auto. That should clear the problem up.
May 15, 2012 | Westinghouse LD-4258 42 Class Widescreen...
Poor picture AVR1600
This is not the malfunction to remote as you thinks. It with the set itself.
Apr 30, 2012 | Televison & Video
I have a Philips CL043 universal remote. I can't find th tv code for a Westinghouse lcd tv.. can you help?
You can find codes for the remote here: http://www.urc.philips.com/ . Then look up the CL043 and click on the remote code finder. This is also called the SRU3004WM by Philips.
A Westinghouse TV should responds to one of the following codes: 0915, 0013, 1216, 0300 if the TV was released 6 months before the remote was programmed or earlier. (Whte Westinghouse codes are different.)
If those codes do not work, there is a manual code search option. With the TV on, press and hold Setup on the remote until the red indicator stays lit. Then press and release quickly the TV button on the remote (the LED will blink once). Then press the Channel Up button until the TV responds (up to 300 times). If you overshoot, press Channel Down to go back to the previous code. Press and release the Mute button to set the code. Check if the remote performs all the needed functions. If it doesn't, repeat the above steps to find another code.
I hope this helps.
(if the remote is older than the TV, you may need a newer universal remote.)
Jan 08, 2011 | Philips 5-Device Universal Learning Remote...
Televison & Video Logo
26 people viewed this question
Top Westinghouse Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
