Question about Samsung 50 in. Plasma TV
My samsang plasma tvps50q7h picture satting frequently change
Samsang hpr4252x/Xsan. Screen light but no pics
If the set is connected with a cable or sat box and or a receiver: Unplug set and box and or receiver from power for several minutes and power back---any of them locked up inside will cause this---I will presume you have checked for this on all inputs the set has.
Dec 10, 2012 | Televison & Video
My 50inch plasma is getting red blotches all over and very frequent? what is the prob
you only seed problem on dark picture?...
you need to adj. volt. on y-sus pc board or power board
Nov 17, 2010 | Samsung PS50A466 50 in. Plasma HDTV-Ready
LG PLASMA TV MADE A LOUD POP NOISE NOW PICTURE IS SNOWY
A common problem for these is bad capacitors in the power supply, Remove the back from your TV and look at the power supply on the left hand side.
You will see roughly around 9 x capacitors that are bulged / domed shaped on top usually these are valued at 3300uf 10V any that have bulged or leaked a brown like substance should be changed.
This will cure the problem as they overheat being sat next to a heatsink that gets very hot!
Try and change them for the same 3300uf but a higher voltage.
Hope this helps
Jun 16, 2010 | LG 42PC3DC 42 in. Plasma HDTV
Panasonic TH-42PX75U Blue Screen
This could be a reception problem of the cable transmission or the cable box if used. Are you using cable or SAT box. Tv goes to blue screen if signal is weak automatically.
Dec 03, 2009 | Panasonic TH-42PX75U 42 in. Plasma...
My plasma LG TV has a black display box in the top left corner of screen. No words or text in it, just a black box covering that coirner of picture...how do I get rid of it?
There should be a button on your TV remote that will be called "Display" or "P in P".
The display button usually displays which input you have selected, such as: SAT for Satellite; AV1, AV2, AV3 or AV4 - depending on how many inputs your TV has, to plug in devices like a VCR or DVD recorder/player.
Otherwise, if you have a more sophisticated TV, it could be that you have accidentally pressed the "P in P" button, that selects the Picture in Picture mode. If you have done this, your TV will display the main picture of the input you have selected, plus another input, (such as SAT or AV1 or AV2 etc. as I've mentioned above). If the AV1 or AV2, etc. input is not active (not switched on) then that input will only display a blank (black) picture in the top left corner of the screen.
Hope this helps...
Nov 17, 2009 | LG 42PX5D 42 in. Plasma HDTV
SAMSUNG sp-p4231 sound, but no picture
try changing the display IC that would be the frequent cause of such problems
Jul 04, 2009 | Televison & Video
Can not change inputs.
seems to be fixed. the only change was a shot surge ptotector. if its a short the problem will return.
Mar 23, 2009 | Hitachi 55HDS69 55 in. Plasma Television
Tv samsung plasma
If it has not tuner/antenna input then it is just a monitor. At that point you will need a cable box,sat box or something to provide a picture scource to it.
May 26, 2008 | Televison & Video
Plasma Tvs
When switching to STBY raster remains and buzz noise is heared from the speakers
Cause: +B voltage (103 V) does not switch-off. Remedy: Replace defective C541
Ticking noise and line in picture
Transistor 7381 (BC848C) defective when hot
Dead with ticking noise from line
Replaced C622, C604 and Q509
Nov 26, 2007 | Televison & Video
Samsung  50 in. Plasma TV Logo
22 people viewed this question
Jerry Greenberg
Jerry Greenberg
Ekse
