Dan Serra Posted on Nov 05, 2019
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My stereo speakers have little power
Speakers are low volume and scratchy
Larry Stiles
Level 2:
Champion:
  • Expert 301 Answers
  • Posted on Dec 11, 2019
Larry Stiles
Expert
Level 2:
Champion:
Answers
301
Questions
0
Helped
87537
Points
443
Would be nice to know the model of the item you have. Low sound may just be that your tape monitor switch is on. Noisy switches may need to be cleaned. I use de-ox-id or de-ox-it. contact cleaner
5 Related Answers
Michael Borelli
  • 979 Answers
  • Posted on May 01, 2008
SOURCE: Yamaha RX-V861 Low frequency "flutter" after turning on
How close to your video monitor is this rxr? It is not shielded well as far as sync circuits in your TV are concerned. Refer to manual...accordianman
Anonymous
  • 558 Answers
  • Posted on Sep 26, 2008
SOURCE: very low volume
Thanks for using FixYa.
I would like to tell you its amplifier is not working properly. May I know with which you are using it right now (With PC or Television).
Please download the Owner Manual for your product attached here.
Manual
Let me know if you need further help.
Regards
Ellin
Anonymous
  • Posted on Apr 18, 2009
SOURCE: Very low speaker volume with all controls maxed
Problem solved... It's embarrassing to report actually. The A3 has a manual volume control knob which sits quite inconspicuous at the front RH side of the case. Just never noticed it...
Anonymous
  • 1555 Answers
  • Posted on Aug 04, 2009
SOURCE: Suddenly my speaker volume is low and scratchy
Congrats, you yourself is a good troubleshooter. Just pinpointed your problem. What you just diagnoist can be easilly checked just by taking other good known speaker. If that works your speaker is short check for audio output wires. If not your card needs replacement. If need further clarifications just comment.
Grubhead
Grubhead
  • 5755 Answers
  • Posted on Dec 27, 2009
SOURCE: Volume at 10 produces very low speaker output.!?
It sounds to me that all you are getting is the pre-amp stage of the amp and nothing from the power amp stage. As it is on both channels then it is something that is common to both. This could be something to do with the power supply of the power stage. Or whatever is on the heatsink. It could be that the amp uses a single audio amp IC for both channels. If it does my bet is that it's gone. If it uses two sets of semiconductors for the right & left channel it would be highly unlikely that both channels have gone, but not impossible.
Why is my soundfreaq speaker going in and out of volume?
You didn't indicate the model so just going to throw out a common problem with that symptom. If there is a rotary volume knob and it causes "scratchy" audio when rotated then the potentiometer(behind the knob) needs to be cleaned. Open the speaker to access the potentiometer and spray a little WD40 inside the potentiometer (if possible) then rotate the knob a few times. If it was scratchy before and is no longer then the problem is likely solved, reassemble then test. Most other problems are somewhat more complex in troubleshooting and I would need much more info. Good luck!
tip
Scratchy sounding volume controls?
If you have a scratchy sounding volume control or your channels cut in and out when adjusting the volume you are most likely suffering from a dirty potentiometer (volume knob) Fully disassemble your DTT2500 unit and liberally spray electronics cleaner in every party of the volume knob (and the other knobs as well). Let fully dry before reassembling.
1helpful
My crossover on Behringer speaker cab ba-115 (15" bass driver plus tweeter) is bad. Does anyone have the schematic before I tear it apart?
There is very little to an inspeaker crossover that could go bad unless it was SEVERELY overdriven. I recommend checking the speaker individually on a wire from a stereo or something powered to verify this. A crossover is nothing more than a capacitor (high cutoff) and an inductor.(low cutoff). The 600 watts rating of the cabinet is an RMS rating, meaning, .707 actual peak value free of distortion. This means that you can only drive it about 71% of that without distorting or damaging it. You said, "very little signal gets to the speaker", which sounds like "very low volume" meaning, magnet stuck, speaker not moving much, meaning warped voice coil. Check that the speaker will move back and forth with your hand freely without interference or scratchy noise. If it doesn't, the voice coil is warped and the speaker needs to be reconed or replaced.
Mar 12, 2013 • Music
Sound is real scratchy and interrupted.
Speakers probably need to be replaced.
I listen to my iphone on my Logitech speakers on my desk. When the volume is low, the speakers work great. However, when I turn up the volume, the green light fades, and the speakers are scratchy. Is...
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Making scratchy sounds through speakers when music is playing
The speakers inside it have aged and their membranes have become weak and they crumple under the load. Unfixable - either listen to a much lower volume or get new ones.
Cp100 hard to hear, scratchy and low volume. perfect sound using ear piece.
Do you use the device in an environment where metal filings are present? This may have clogged the internal speaker in the device. Water or dirt will cause the same problem, though metal is most often the issue.
Try using a powerful magnet to draw out any metal stuck to the speaker surface or housing.
Lights are on in the small speakers but no sound is produced...there is a short scratchy sound when I juggle the speker wire from sub woofer. I hooked speakers up to a different MAC and now am trying to...
Hi there , the green light just means its getting Power, it doesnt mean that its going to give sound, It could be that you dont have Drivers installed for your Sound card which is causing it too not get sound , but when it makes that static noise , its the Wire just causing Static with the Sub , just means its getting power , The + and - sign is the volume control ...Try see if you can turn it louder with the + . maybe it is low enough not too hear.....Hope this helped Bud
Happy new year.
2answers
2helpful
 Grubhead
Grubhead
SmartAviator
SmartAviator
