Question about Boss Music
My boss br-1180 out put is distorted its fine with head phones i tried all the basics stuff to solve the problem with no luck
5 Suggested Answers
6ya staff
SOURCE:
Anonymous
  • 27 Answers
SOURCE: MY Boss br 1180 ,disk error
before you go out and buy a new hd try intializing your system.
unfortunaly you will lose all saved info, but you will either way. this test may save you some money.
with your 1180 in the off position press and hold the track 5 button below the fader and the redo/undo button that is just to the left of the rotarty knob and below the power button. while holding these two buttons press the power button and continue to hold the track 5 button and the undo redo buttons untill the test menu is showing. its takes about 15- 30 sec. in the test menu rotate the value knob till you see 23 initialize HDD and press ok. this process may take up to 30 mins. if this doesnt fixya then contact roland for a replacement.
Posted on Feb 26, 2009
CRTN
Michael Fisher
  • 716 Answers
SOURCE: What do I need to burn a cd from my pc with the br 1180
This Is real simple grab a cable that goes from rca jacks to a headphone jack then plug the rca jacks into the br-1180's audio out jack and then plug the other end into your computers mic port.
Download Audacity From www.Audacity.com and then use it to capture you audio and then you can burn that when complete.
Its real simple I do it all the time even though I have the br-1180cd the cd burner burns real quiet so I don't use it. The cable can be bought at radio shack, best buy, wal-mart and I have even seen them at 99 cent only stores.
If you have more question let me know This Is my main unit so I know a lot about it.
Sincerely,
Michael Scott
Posted on May 04, 2009
theariston
  • 9 Answers
SOURCE: Is the Boss Dr-5 compatable with the Boss BR-1180 mini studio?
The beats you have programmed into the drum machine will not play through the midi cable. In order to do what you want you need to connect the audio output from the drum machine to the audio input of the br-1180. What you should then do is connect the MIDI out of the the br1180 to the midi in of the Dr5. This will allow you to start and stop the drum machine with the play button on the br1180. MIDI can be a complicated thing so be sure to RTFM about MIDI for both of your BOSS devices to understand what they can do to work together. Good Luck
Posted on Dec 14, 2010
mantonrocker
  • 6 Answers
SOURCE: Hey i just got a
Troubleshoot. Try different cables, mics, instruments, etc to make sure that its the device and not something else.
Make sure you don't have any digital effects (compressors, guitar effect simulators, etc) activited.
See if there's a way to restore the device back to factory settings. Make sure you backup your recordings first.
Posted on Jan 15, 2011
I can not download off br says usb idling.I put card in laptop i think it says unsupported format.2 and 8 gb dont work I took card out of old camara drag pic to laptop no problem.Put recorded music on...
Moost of these will only use a max card of 2Gb. There are some conversion programs. There was a lot of discussion at one time on Vsplanet dot com about these units if the site is still active.
May 12, 2011 | Boss Micro BR Digital Recorder
Hey i just got a boss br-864 and it was recording fine but now i cant seem to get rid of the distortion.Tried adjusting the input level and sensitivity but no luck.Would appreciate any ideas,thanks.
Dec 31, 2010 | Boss Micro BR Digital Recorder
BR-1180 freezing & high-pitch ring
Check your power supply to the unit. Low voltage COULD cause this.
Also make sure a setting is not "looping" the audio back into itself.
May 23, 2010 | Boss Micro BR Digital Recorder
Burnt out my Boss BR 1180 How do I repair?
this is a job for an advance electronic repair tech...try the manufacturer..next a tv repair shop..then an Audio Install shop...if that doesn't work out..i'll personally try to fix it..for lest than anyone else..its probably the tranformer output circuit overrun..that part of the board or component wil have to be replaced...good luck
Jun 16, 2009 | Boss Micro BR Digital Recorder
No CD writer for Boss BR-1180
Hey mike yeah you can hook a regular cdr drive to the ribbon but the problem is if its not a slim it most likely wont fit inside the unit. Also the built in c.d r is way over rated mine has it and I still bounce it all onto my computer and then burn it from there. The one on the br-1180cd burns very quiet.
Apr 23, 2009 | Boss Micro BR Digital Recorder
Boss 1180 Hard Drive Error
Im Sure You Solved This Problem But For Other User Yes There Is A Way To Save Your Data If Your Hard Drive Is Still Operable. You Can Put Your Boss Hard Drive Into Your Computer And Copy Its Contents To Your Computers Hard Drive. Some Say That If The Hard Drive Is Not Operating You Can Put It In A Ziplock And Then Stick It In The Freezer For An Hour Then Attempt To Retrieve Your Info. Remember Always Back Up Your Data On Hard Drive Recorders As They Are Not Fail Safe.
Apr 13, 2009 | Boss Micro BR Digital Recorder
Midi doesn't actually "make sound". If your trying to record the patterns you made on the DR-5 to the recorder you need to use an audio output(I don't remember if they are RCA or 1/4" on the DR-5.) The midi output would be used to"trigger sounds" in another device that has sounds built in, or you could also trigger sounds in a program that supports midi input.
Mar 03, 2009 | Boss Micro BR Digital Recorder
Dec 06, 2008 | Boss Micro BR Digital Recorder
Music Logo
Top Boss Music Experts
Michial Gueffroy
Mosaub Al Masri
Mosaub Al Masri
rhodesworks
Are you a Boss Music Expert? Answer questions, earn points and help others
