Question about Westinghouse Televison & Video
I have a westinghouse tv and latly its been turning on and off byself ,it will play a couple of programs and just turn off and come back on by itself.w h ats wrong with my tv is it the cord?
    Top Expert:
  • Westinghouse Master
  • 66,248 Answers
Sounds like you may have set the program timer accidentally
Posted on Nov 06, 2019
6ya staff
SOURCE:
SOURCE: Turns off by itself!!!
The flyback transformer are damaged .
Posted on May 28, 2008
Anonymous
SOURCE: Westinghouse LTV 19w3 shuts off
The same thing was happening to mine and the problem was in the power supply. Apparently, there was a loose connection causing it to go in and out. The round connector end that plugs into the monitor has two prongs on the inside. I was able to bend each prong toward the center with a thumb tack so that it would have a tighter connection, and it now works fine. Unplug from wall before working on the prongs.
Posted on Feb 23, 2009
ArnelM
Arnel
  • 184 Answers
SOURCE: my sony grand wegar tv
If you haven't done so, replace lamp part#XL2000U
Posted on May 27, 2009
Anonymous
  • 3 Answers
SOURCE: Westinghouse LTV-20V4 turning on PROBLEM
I had this problem with these tv`s. As mentioned the problem lies with the power supply inside the unit. Some of the units i`ve seen have 2 blown capacitors on the power supply (C7 and C6 which are 0.227microFarad) replacing these works. On others, the capacitors as well as a few transistors
(Q8 - Q1, HSD965) are blown. But on all the sets i have seen with this problem, changing the above components restores full functionality to the system.
Posted on Jul 20, 2009
Anonymous
SOURCE: Westinghouse 32 in LCD TV
I have had this problem now for about six months with my Niko OPT-3211W. After replacing the Inverter card, VIT70002.00 as suggested nothing changed. I then read that it may be a couple of capacitors in the power supply, but I do not have the skills needed to replace them, nor do I want to pay to fix it. The solution is simple... turn on the TV and wait two to five minutes, then turn off the main power. I suggest using a power strip. Then turn the power back on in two to five seconds. The TV will come back on and it works great from then on. I thought that it was a freak thing, but it keeps working.
Posted on Aug 23, 2009
How can I get a new remote for my ilo tv
you can get a universal remote. an rca works great from walgreens or walmart. it will give you all the info. manual direct codes are 11286-11603-11684-11990. otherwise hold the power button along with what you want to program, and wait until the light comes on. Then press play every couple of seconds until the tv turns off. Then hit reverse every couple of seconds until it turns back on. Then hit stop and its programmed.
Jun 14, 2010 | iLO 2600 Television
Tv not turning on
I have this same problem and I just fixed it today. I'm not sure where the problem really is but when i took everything apart and disconnected everything and put it back together it turned on and is now working! I still have one problem now, when i turn it off, the screen goes a bright white but it says that's it's off. If you ever find a solution to that please e-mail me at bmebme26!yahoo,com
Jun 08, 2010 | Westinghouse SK-19H210S Television
My westinghouse 27 inch panel shuts off on its own but the front panel light stays on. You have to shut the tv off and turn it back on to macke it work again. It doesnt always work the first time
does it have any Eco settings, or auto shutoff after certain time settings. Not sure if they do anything about that, but there has been a handful of times over last couple years when my 32 in Westinghouse would either turn off, and not start, or simply not turn on. Had to uplug and wait a min a couple times. I have considered updating the firmware, but have heard so many horror stories about this on Westinghouse TVs I am afraid to try it. Just flashed new firmware onto my new Sony TV yesterday, no problems. Westinghouse has some funky issues with different hardware/firmware in same model TVs, and you have to turn off Autosource in power menu. So some peoples problem are probably cuz they didn't follow directions and bricked their tv. But some who suceeded and said it was easy no problem, still ended up with other new issues, and a firmware update is irreversible. If it only happens once in a while, I say live with it, or brave the firmware and give that a shot. I haven't tried Westinghouse support, but have heard it is less than desirable.
Drop me a line if ya want,
alchemancer@yahoo.com
Jan 20, 2010 | Westinghouse 26" LCD Flat-Panel HDTV
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
40" LCD Westinghouse Pictures comes and goes rapidly
Take it in to a service center for an Estimate. Parts are very difficult for Westinghouse sets.
Jul 15, 2009 | Westinghouse Electric VK-40H580D 40 in....
My hdtv 46 inch Westinghouse TV lost video in the middle of a program. I have checked all connections, turned off the TV and turned it back on and nothing works. Can you help?
Westinghouse are throw away TV's and it is most likely the case you will want to replace it. How long have you had it. If its still under warranty use that otherwise you will need to replace it.
Thanks,
Lee
Jun 17, 2008 | Televison & Video
Remote good but will not work with Westinghouse LTV 32w1
I fixed it by powering off the tv and waiting a couple of minutes and powering it back up. I should have thought of that first!
Apr 29, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
TV turns on by itself
Just change all the buttom (switches) including: volume, channal, power, and menu buttom. That is the only problem
Nov 20, 2007 | RCA D52W15 TV
Jun 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
Televison & Video Logo
22 people viewed this question
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
