Question about Sansui Televison & Video
I have a universal remote by EZ digital RM-L1107+8 and I need the code for a Sansui TV. Can't seem to find it.
6ya staff
SOURCE:
Anonymous
  • 17 Answers
SOURCE: need code for my for my sanyo tv using sony universal rm-vl600
http://esupport.sony.com/perl/model-remote.pl?mdl=RMVL600
Posted on Jan 06, 2009
greenspan
Remmy Moore
  • 1734 Answers
SOURCE: Sansui TV code for a rm-ez4 remote
Ask Manualfox.com - it is a personal Document Search Service for electronic user, service manuals and drivers. They help you to save time and money by finding your needed product information.
Posted on Feb 22, 2009
professio101
Robert Engel
  • 158 Answers
SOURCE: i have a chunghop universal remote, RM-133E and i
I could not find the code, but here is a solution that should work. Please give me good rating
1. Manually switch on the TV set, and aim the remote control at the TV set, as shown in the figure:
2. Hold the "SET" key until the indicator light illuminates.
3. Repeat to press the "VOLUME +" key and see whether a volume symbol appears on the TV screen.
4. Upon appearance of the volume symbol, press the "SET" key immediately, and then the
indicator light goes out.Setting is finished.
5. Test whether the keys on the remote control function well; If keying does not work, reset from Step 2.
Posted on Jul 01, 2009
Anonymous
SOURCE: code for universal remote rm-810
There is an easy way to setup this remote controllerl(RC). It called "Automatic Code Searching" which means that you don't have to even find the code. The controller will searching it for you. Just do the following steppes.
1. Turn on the "Device" to be remotely controlled, e.g. TV, VCR.
2. Point the RC right to the "Device" .
3. Press a device button on the RC represent the "Device", e.g. TV, VCR, DVD etc. You can see the indicator lid flash once.
4. Press the SET and than the POWER button on the RC. hold both buttons for 2 seconds or more, you will see the red lid on. then release both buttons simutenously. after that the indicator lid will be flashing, means the searching started.
5. Keep pointing the RC to the "Device" until it is shut down by the RC, Press any button in 1.5 second to finish the setting.
You can try the RC now. It should work. My one is working.
Posted on Apr 09, 2010
Robert Kitaji
  • 1335 Answers
SOURCE: i digital universal remote RM-810 - need code for
Try 184 for the NEC TV.
Please rate this solution. Thanks.
Posted on Sep 02, 2010
I have a universal remote control from EZ Digital the model is RM-L1107+8. I need the 3 digit code for a Dynex Television Model DX-L42-10A
Use code search to find something that works. if a search through all codes stored in your RM-L1107+8 fails, you may have to try a different URC. All URCs do not contain all possible codes.
Jun 21, 2018 | Universal Remote Control Televison & Video
Could not find hauyu remote rm 36e+ codes for sansui tv
Sep 11, 2013 | Universal Remote Control Remote Control
I need a code for my remote control?
Hello
You hven't given any specification of the remote control you have. Yet I hereby send you universal remote codes for Sansui herewith.
Three digit universal remote codes for Sansui are:
135/ 136
Four digit codes to check with are:
0135 0310.
Four digit code for Sansui TV/VCR cobo is:
0310
  1. .
Nov 02, 2011 | Sansui COM312AD 13" TV/VCR Combo
I have a lcd sansui SV-3255LCD tv but the remote had quit on me. can you people help by supplying me with the code for my LCD? And will the code for my LCD work on my sony universal remote RM-AAP013?...
Sansui is built by Japan firm Orion try 135 or 136 four digit try 0135 or 0310
On the remote control, press and hold the RM SET UP button.
  1. While holding down the RM SET UP button, press and release the A/V I/O button.
  2. Release the RM SET UP button.
  3. Press the input (component) button to be controlled. NOTE: To program a television press the TV I/O button.
  4. Press the number buttons to enter the numeric code corresponding to the component and the make of the component to be controlled. NOTE: If more than one code number is listed for the manufacturer, enter one code at a time until you find one that works.
  5. Press the ENTER button.
hope this helps
Mar 28, 2011 | Televison & Video
I need a remote code for my tv for a comcast remote i have a sansui tv thank you
hi,
Try the following codes
5 digit code :- 10463, 11409, 11904, 11911,11935 (Comcast Universal Remote )
4 digit code :- 0463 (COMCAST - CUSTOM DVR-3 DEVICE UNIVERSAL REMOTE CONTROL)
ok
Jan 14, 2011 | Sansui DTV2760 27" TV
I have a sanyo remote and a sansui tv how do i program the tv
Hello
I don't have a code for Sansui TV to be programmed with Sanyo remote control But hava a philips Universal remote model which can be programmed for Sanyo TV and has its codes.
Remote Model ===> Philips CL 034 Universal Remote Controller.
Codes
0115 0632
And herealong with I sends some universal remote codes, that you can check it for.
Four Digit Universal remote code for Sansui TV are
0135 0310
Three digit universal remote code for Sansui TV are
135/ 136
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Nov 25, 2010 | Sansui Televison & Video
I digital universal remote RM-810 - need code for
May 28, 2010 | Universal Remote Control Remote Control
Feb 22, 2009 | Sony RMEZ4 Remote Control
Televison & Video Logo
37 people viewed this question
Top Sansui Televison & Video Experts
matt martin
matt martin
Ekse
Are you a Sansui Televison and Video Expert? Answer questions, earn points and help others
