You need to ask HP, that, it's laptop right?
is this and HP ENVY notebook????
Pavilion notebook?
we need the PCs service tag product number,
15 means nothing, ever.
the number may end in #ABA! mine all do.
tell that and HP can help.
The newer the PC the more hard this becomes
BY DESIGN !!!
hp 15 is not the full model name:
example #1, the service tag is read first, then told what it is. (wild example #1)
HP 15-bs031wm then go here and ask HP, what to do. notebooks
https://h30434.www3.hp.com/t5/Notebooks/ct-p/Notebook
BIOS PW lost. (next time do not use this unless work for CIA/DOD ,etc)
HP has fix, call them, online lots of $scalpers, sell it.
The year the HP laptop was made also changes the answer.
Here are the historical evolution of HP PW.:!
1: long ago jumpers on the motherboard.(kids stuff)
2: then coded, eeprom PW chip used, and backdoor PW that HP tells you after you enter PW blank 3 times.
you see code only you have and HP tells the new PW.
3: then TPM chips and UEFI, the new age. (hard nut )
only HP can cure those PERIOD. Not scalpers..
4: also what you turned on in bios can also make this worse. like fingerprint logins, etc...
I own and HP8540w that can get in 3 ways. 2010 made.
BIOS PW
finger print swipe
and the magic intel way me answering 3 questions.
what you have NOBODY KNOWS what you turned on...
that be first after posting your service tag.
that tag.
here ill beg for your tag... sad no?
HP moved the service tags many times
easy see on bottom then on laptops, in the battery well battery out. and last no tags at all , only seen in BIOS screen 1. (now locked out ouch)
see hp 17 here, the letters after the number matter.
the product number matters most. !!!!
https://www.pcdied.com/TAG-jive/hp-17-ours1W.jpg
HP is not dead, ask them first.
do not ask or respond to scalpers seen here.
nor pay them $100 and then the cure fails.
https://h30434.www3.hp.com/t5/Notebooks/...
here HP.com is
it is the real thing.!
New laws in effect in USA and in EU.
force the OEM to make you prove you own the PC first, and ban hacks. all by law now.
OK consider that first.
and how that helps hackers get rich.(scalping)
best is not to use BIOS passwords, or land HERE.
go there and ask.
or learn to post your service tag data.
for old PCs the hacker page is here
http://dogber1.blogspot.com/2009/05/tabl...
most exe you find will be virus infected.
so avoid those.
pwGen-123xyz.exe , ouch.
SOURCE: remove password from award bios on asus laptop
Click on the link below and follow the instruction
http://www.fixya.com/support/r1257563-break_bios_password
SOURCE: How to reset BIOS password for Compaq EVO N160 notebook
Do the following steps -
- Remove the laptop battery
- Remove the CMOS battery
- Leave it for idle for around 15 minutes
- Put the CMOS battery in
- Boot the laptop with AC power
- Then put the laptop battery in.
- The BIOS pwd would have been reset now
- For troubleshotting the battery - Go into BIOS and run the Battery Caliberation tool
Hope this helps.
Thanks,
AK
SOURCE: dell latitude d620 bios password removal
To remove a BIOS password will require the assistance of Dell Tech Support. 800-624-9896 You will have to be able to prove you are an authorized user and if out of warranty a Fee may be involved.
SOURCE: Administrator Password for BIOS lost
A. By Using the Motherboard Jumper:
In most motherboards CMOS battery is soldered, which makes it difficult to remove the battery. In this case we use another method.
Almost all motherboards contain a jumper that can clear all CMOS settings along with the BIOS password. The location of this jumper varies depending upon the motherboard brand. You should read your motherboard manual to check its location. If you don't have the manual then look for the jumpers near the CMOS battery. Most of the manufacturer label the jumper as CLR, CLEAR, CLEAR CMOS, etc.
When you find the jumper, look carefully. There will be 3 pins and the jumper will be joining the center pin to either left or right pin. What you need to do, is remove the jumper and join the center pin to the opposite pin. e.g. if the jumper joins center pin to left pin, then remove it and join center pin to right pin. Now wait for a few seconds and then again remove the jumper and join the center pin to left pin.
Make sure to turn the PC off before opening the cabinet and resetting the jumper.
B. By Using Software:
I have found that BIOS/CMOS Password Recovery Tool is the most effective.:
BIOS/CMOS Password Recovery Tool is a program that works instantly to remove any lost or forgotten BIOS/CMOS password. Simply boot your PC to DOS and execute the program, and get access to forgotten BIOS/CMOS passwords in just seconds
BIOS/CMOS Password Recovery Tool Service: http://www.biospasswordrecovery.com/
SOURCE: I need to remove the administrators password for Dell Inspiron B130 service tag ends in 595B
Dell Laptop with bios or hard drive password set ? Unlock your dell laptop using the link below if it display a message that says "this computer system is protected by a password authentication system, you cannot access the data on this computer without the primary or administrator password, when you turn on the computer. This message is what you get if the BIOS is protected by a password. or you get system disabled
Go to: http://dell-inspiron-b130-bios-password.biospwd.com to get your dell bios password authentication and get full access to your dell computer, they can unlock almost all dell laptop such as dell inspiron, xps, latitude, precision, studio, vostro
