Question about Westinghouse Televison & Video
Atsc tuner code westinghouse lcd tv serial code # 6120Y03201842
    Top Expert:
  • Westinghouse Master
  • 55,370 Answers
The applicable code would be found in a compatible remote control.
Posted on Dec 11, 2019
6ya staff
SOURCE:
Anonymous
  • 1067 Answers
SOURCE: Connecting Samsung TV to a Fisher RS909 Receiver
yes use rca outs form samungto video in on sterio
Posted on Jan 26, 2008
Anonymous
  • 405 Answers
SOURCE: Connecting to Dish Network receiver/tuner
Yes!
Posted on Jun 27, 2008
Anonymous
  • 44 Answers
SOURCE: 52G786 ATSC Tuner no longer works
I have the same exact model tv...Love it...ATSC tuners is in definition an Analog tuner. As the broadcasting companies change over to Digital broadcasting before the deadline in Febuary 2009 more and more local or Non-Digital chanels are becoming obsolete. You would have to purchase a converter box for your tv if your not planning on getting cable. Another way to gois if you have an old cable line running through you house (no incomming cable) plug you tv into that jack. That also acts as a antenna. The sweet part of all this is that your tv do have a QAM tuner or Digital tuner built in just need that digital antenna to pair it up.
Posted on Jan 03, 2009
pabloloco
Paul Sager
  • 2335 Answers
SOURCE: codes for living solutions remote + westinghouse lcd tv
The codes for your Jumbo Universal Remote to control a Westinghouse television are 097, 100, 130, and 155.
To program your remote by entering a code, follow these steps:
  1. Turn on your TV.
  2. Press and hold the CODE SEARCH button for at least 3 seconds until the red LED lights up and stays lit.
  3. Press the TV button on the remote so that the LED blinks once and then remains solid red.
  4. Enter the first set of 3-digit codes from the list. The LED will blink once every keypress. After the 3rd digit, the red LED will turn off indicating that the code was recognized for the device. If the code was not compatible, the LED will flash several times and you need to return to step 2 to try that code again or to try the next code in the list.
  5. After the LED has turned off, aim the remote at the TV and press ON/OFF. If the device turns off, you have used the correct code and the remote was successfully programed. If the device does not power off, return to step 2 and try again with the next code in the list.
I hope that helps.
Posted on Oct 16, 2009
gopakumarg43
  • 76204 Answers
SOURCE: Access code for westinghouse tv model LD-2240 serial 6616121307447
You're asking about its service mode code I assumes, and posts this solution. Visit the site named 'Electro-help' for more details. Check this link and select the site named above. View it in 'Flip card' option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. It will make search easy. Some times, the ads attached with each posts, both at the right and bottom, might help you to find the availability of spare parts. There are more than 750 posts to different brand TVs now
Posted on Sep 14, 2012
Nesesito c?digo de Westinghouse Modelo: VR-4025 N?mero de serie:6330Y11900335 Tipo de exploraci?n de Canales:ATSC
He is asking for:
Westinghouse code Model: VR-4025 Serial number: 6330Y11900335 Channel scan type: ATSC
but I can't be SURE of what he needs>?
Anthony
Apr 15, 2018 | Televison & Video
Westinghouse LTV-32w4 HDC widescreen DVD Combo
Hi Mouse999. From reading a bit, it seems that there's no region free hacks for the built in dvd player in that specific model. A solution for you, would be to purchase a standalone dvd player, one that is region free or one that has a region free hack available, and to connect it to that tv. If you're in europe and your tv is pal, you also need to have a dvd player that will read both Pal and NTSC video dvd's ! If that doesn't help, please be more specific, i'll be glad to help. Thanks, cheebster.
Jul 10, 2007 | Westinghouse LTV-32w4 32.02 in. LCD HDTV
How do I get my 7" widescreen lcd tv with atsc tuner to show channel numbers?
ATSC Digital (VIRTUAL!) Channel NUMBERS vs Actual Channel ...
www.avsforum.com/.../1260172-atsc-digital-virtual-channel-numbers-vs...
Jul 2, 2010 - 4 posts - ‎4 authors
Then came ATSC tuners and digital - [I was about 20 minutes into .... *SHOULD*display the SAME VIRTUAL CHANNEL NUMBER when tuned ... iView-3500STB Tuner & DVR Owners Thread - AVS ...
Mar 30, 2013
OVER-THE-AIR DIGITAL TELEVISION RECEPTION ...
Dec 3, 2005
More results from www.avsforum.com
Jan 13, 2016 | Televison & Video
TUNER ACTIVATION CODE LD3288M,SERIE:11196212194
I have a problem whith TV, LCD :APEX , model:LD3288M serie:11361580239 ,, i need the tuner activation (ATSC), code for the channel,, please help me, my e-mail : moril_23@yahoo.com
Apr 23, 2013 | Apex Digital LD4088 LCD TV
Need atsc tuner code for Westinghouse Lcd tv model cw40t8gw
Need code :VR-4090
6530173500349
Exploraci?n de canales ATSC
Jan 09, 2013 | Westinghouse Televison & Video
I have a 32 inch Westinghouse LED slim tv. I try to put a attena and it ask me for a 5 digit access code . I have no idea what's the code. Can you help me.
You have to go to http://wdsupport.net/wdeonlineservice/tunercode.aspx to get the access code to unlock the ATSC tuner. Find your TV model in the list on the right then enter the serial number in the box. The code should appear below that. You can also request a copy of the access code by email. If you have any problems, call the Westinghouse customer service line, 1-800-701-0680, during weekday business hours.
I hope this helps.
Apr 13, 2012 | Televison & Video
Obtain Tuner Activation Code Serial Number: 6200Y04102884
Westinghouse.com/support then go down and click tuner activation put your serial number in to your right and hit enter and you got a code
Dec 05, 2010 | Westinghouse Electric LD-2655VX 26 in. TV
I don't know if my TV's digital tuner will work when they switch over to digital broadcasting. My TV does have one but during a test it didn't work
The Sharp LC-19SB25U 19 in. HDTV LCD TV has both a NTSC and an ATSC tuner.
The NTSC tuner will stop working in Feb. 2009 but the included ATSC tuner is what you need for after the digital transition.
If this is not the model number or manufacturer of your TV, then please post them.
Dec 06, 2008 | Sharp LC-19SB25U 19 in. LCD HDTV
Televison & Video Logo
Top Westinghouse Televison & Video Experts
CoppellTVRepair.com
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
