Hi, it could be that the door was left open for some time and caused moisture to enter. Try thawing out the freezer first by unplugging it for 10 hours. Best of luck!
Ned
5 Most Common Freezer Problems and Solutions
https://www.searshomeservices.com > blog > 5-most-common-freezer-prob...
#1 PROBLEM: My freezer is making strange noises. ... Keep in mind, though, that not all freezers will make exactly the same sound when this ... If everything is working, then the noise is probably just the appliance going ... Frost forming around the freezer door's gaskets indicates the door was not fully closed. .... Sign me up ...
Missing: 5.3 cu ft HNCM053E
SOURCE: chest freezer
Need to find out IF the compressor is running or not.. thats the frist thing to do.
SOURCE: Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first. 1. Is there a thick frost buildup on the back panel at the bottom half of the freezer? 2. Do you hear the fan running inside the freezer? Let me know what you find.
SOURCE: new chest freezer not getting cold
I am having the same problem. How long did it take?
I bought mine second hand and think it may be broken. I plugged it in 8 hours ago. I can hear it running but it's not cold yet.
stopped up drain,tear in gasket,not going into defrost soon enough
