Question about Samsung Televison & Video
Samsung B2330HD IR sensor location?
I need to find the sensor location for the infrared to disable a TV remote from working on this monitor , cover with tape or anything to just disable .
6ya staff
SOURCE:
Rommel Balcita
  • 749 Answers
SOURCE: Infrared sensor not working
try changing your remote's battery and look for loose connections inside the remote control
Posted on Dec 05, 2007
Anonymous
SOURCE: Need Infrared Remote Code...
I had the same problem and it took an act of Congress to solve it. However, I can tell you that through much more hard work and time than it should have taken I discovered the infrared code for my "One-For-All" remote model URC-4021B00 is--0651. Not sure if it's the same for any other remote control models, but give it a shot.
Anonymous
SOURCE: COMCAST REMOTE AND SAMSUNG TV
I was having the same issue with a Samsung 4053 40"
Comcrap had no clue.
Their phone rep suggested I come in and trade out the remote. That seemed unlikely if others are having the same experience. It is also unlikely a phone rep would have any answer other than what on the web page.
I used 5 digit code "10060" and it worked got the double flag from the remote like Comcast's documentation says. It turns TV on and off and works volume. So far so good.
The key to figuring it out was getting the double flash on the remote 4 digits didn't 5 did.
The moral of our story? Comcast has no clue what they push out the door. I guess that isn't a surprise to anyone.
Posted on Jan 13, 2008
Anonymous
  • 40 Answers
SOURCE: Toshiba 50A62 Remote Infrared Sensor
I have replaced these IR sensors before and it has solved the problem...they dont blow all the way..they just get weak......replace it.
Posted on Jan 26, 2008
Anonymous
SOURCE: Sony KP-53HS10 TV Infrared remote sensor problem
Hey, I called the local Sony Authorized dealer/repair. He said the little microprocessor inside the sensor goes bezark once in awhile......soo.......unplug the TV from the wall when you go to bed and then plug it back in the next morning. It worked for me. The little gizmo resets itself.
Posted on Mar 05, 2009
Where is the remote sensor located on the Toshiba TN55X81 TV? (I need to locate for placement of IR transmitter.) Thanks!
a neeto hack to do this is to use a electronic video camera (your phone works too) , just set camera to no back light or low light , and using your remote pointed at tv , view the tv thru the cameras view finder , ahhh there it is !!! it twinkles at you !!!
how this works is that electronic video cameras for low light can see wider spectrum of light than human eye they then interpret it and send it to the monitor or screen , and hey infrared remotes are "wide spectrum "
Dec 13, 2016 | Toshiba Televison & Video
Why wont the remote control feature work on my Panasonic TCP50UT50 Plasma, is there a feature to disable the remote, panel works well
Check the remote control for its infrared emission. Check it with fresh batteries. If you wish to get more details about how to check a remote control, please visit this site. One among the posts has details about it. Surf the site with patience.
Jul 21, 2015 | Panasonic Televison & Video
Remote IR board
This board can be located at the front panel of the TV. You have to open the TV, to take it out. The infrared sensor can be located just behind the infrared window, whci can be located at the front panel of the TV. The sensor will look somewhat like this. e23a7382-203e-4e46-a063-a2a3486f559a.jpg
If you wish to get some details, check the site linked here. Surf the site in "MOSAIC" view. It will make surf easy. Surf the site with patience.
Jan 29, 2014 | Samsung HL-T5076S 50 in. TV
Samsung ir sensor
Infrared sensor can be located, just behind the infrared sensor window, at the front panel of the TV. You have to open the TV, and take out the front panel PCB, to reach and reparable this component.
The component will look somewhat like these.
If you wish to get some details, check the site linked here. Pull up older posts. Check the site in 'Mosaic' view. It will make search easy. http://electronicshelponline.blogspot.com/
Jan 11, 2014 | Televison & Video
What happens if i disable IR
When you make the infrared sensor disabled, the TV won't response to any remote control there after.
Jul 14, 2012 | Televison & Video
LG 32LD320-ZA remote sensor
Replace the remote sensor. this component can be located just behind the infrared window at the front panel.
Jun 13, 2012 | LG 32LD320 32 HDTVReady LCD TV
I need to replace the infrared sensor unit for Vizio L37 HDTV.
Good day!!!
Before I answer your question let me clarify something..
  1. What sensor you need to replace is it on the remote IR (infrared) or the receiver on your TV?
  2. Did you try other remote control?
  3. How did you say that you need to replace the IR sensor or receiver on your TV?
To test the remote please use a digital camera..How? place the shot to infrared of your remote then look at the screen of your camera after that press any button on your remote and look if the IR sensor lights up..
Please answer all my clarifications for me to diagnose the exact problem..Because replacing of IR sensor on TV is difficult..
Thank you for using fixya and choosing my service..
Dec 11, 2011 | Televison & Video
My samsung led remote control has just stopped working and i can't get it to work again. I've changed the batteries and i cannot find the reset button. I've unplugged the power from the wall and still no...
We need to find out first if the remote is putting out the IR signals or not, or the problem is in the TV IR receiver module.
Testing remote control:
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera's Lens (Digital Camera can detect IR), you should see flashing light on the camera's screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
Parts: www.shopjimmy.com
www.remotes.com
EBAY. AMAZON
Mar 12, 2011 | Samsung Bn59-01041a Remote Control
The remote control sensor on my new television does not work. I have tried several remote controls and none of them work. Is there a way I can fix this myself or do I need to wait for a technician to come...
Unfortunately, only remote can do.
If you have a philip screw driver, soldering iron and soldering lead at your home and have the guts to make the DiY, then, here is what you need to do.
Turn off the TV
On your tv, locate where the ir sensor (infrared sensor). Open the back cover of your television using the Philip Screw driver. Manage to access the small pc board where the ir sensor was attached. Examine closely the ir sensor board. Using your soldering iron and lead, try to resolder all the terminals in the ir sensor board.
After you resolder, then, return it back. And Turn on your televison.
Hope this helps!
Dec 27, 2010 | Mitsubishi Televison & Video
Samsung 5 series 40 remote not working
The remote control puts out IR (InfraRed) signal that human eyes cannot see, to find out if the remote is sending out the signal or not you just point the remote at the digital camera’s Lens (Digital Camera can detect IR), you should see flashing light on the camera’s screen when any one of the remote button is pushed. If you do see the flashing on the camera, then the problem is in the TV IR receiver or the main logic board; more troubleshooting with scope will be needed to look at the signals.
www.remotes.com
Jul 17, 2010 | Samsung Televison & Video
Televison & Video Logo
Jerry Greenberg
Jerry Greenberg
Ekse
