Question about Electrical Supplies
Where can l get a flywheel for my yardworks 2150 power generator
    Sergeant:
  • Electrical S... Expert
  • 358 Answers
Hello, contact your supplier, in generally, they supply spare parts of power generator. But if you still want to purchase other type diesel generator set , please visit at www.dieselgeneratortech.com
Posted on Nov 27, 2019
6ya staff
SOURCE:
My yardworks 2150w portable generator wont start. Thought it was dirt or water in the gas cleaned it all up .not working. Lots of spark no start. Help
My yardworks portable generator 2150 won't start - Fixya
www.fixya.com/support/t14802132-yardworks_portable_generator_2150
Oct 28, 2012 - First check the circuit breakers on the control/outlet panel. Then take the end off the generator and look at the brushes (usually what breaks) and the ...
Why won't my portable generator start? - Home ...
diy.stackexchange.com/questions/.../why-wont-my-portable-generator-st...
Mar 6, 2013 - The generator is fairly new -- I bought it at the end of June '12. ... An E 3 spark plug is always a good start, Stabil (fuel stabilizer)in the fuel or ...
the generator in parts, accessories - Alberta - Kijiji
www.kijiji.ca > Alberta > cars & vehicles > RVs, campers, trailers KijijiLittle hours on this generator comes with command start was over $ 500 just for the starter. Yamaha ... Yard Works 2150w generator. Generator starts ... Wanted generator for my camper at least 1500 or more ... You won't see more new motorcycles at one place anywhere else. ... New Champion 4000watt portable generator.
Power Generators New ' Kijiji: Free Classifieds in Alberta ...
www.kijiji.ca/b-alberta/power-generators-new/k0l9003 Kijiji
Dec 18, 2015 | Electrical Supplies
How to remove a flywheel from 2000w generator
Use a gear puller to remove it. To reinstall it put a little bit of grease on the shaft align key way on the shaft to slot on flywheel pushing it down on the shaft to get it started then use a block of wood on center of the flywheel over the shaft strike the block driving the flywheel on to the shaft till the flywheel is even with the outside edge of the shaft. Put your bolt back in the shaft use some thread locker sealant on bolt threads before you install it. Hope this helps you.
Jan 01, 2015 | All-Power America All Power 10000w Apg3090...
Yardworks 270-1241 battery full charge, sound like fan runs no motor, blade goes around, help
sounds like your starter pawl is stripped. remove your starter and inspect the pawl (gear). also check your flywheel teeth for chipping. this is usually a replacement part. If your flywheel is good just change the pawl on the starter itself
Jun 29, 2014 | Yard Machines Garden
Poulan 2150 saw will not start.
Many saws today have a alluminium key moulded into the flywheel, if the key has sheared the timing will be out and it will never start, remove the flywheel and check the key.
Jun 05, 2012 | Poulan Garden
Yardworks 3500 generater back fires
I need a gas tank for yardworks generator 3500 can you help me?my add.jacques486@sympatico.ca
Jan 11, 2012 | Electrical Supplies
Whats the flywheel gap for a poulan 2150
hi there, this is what i have found so far, i will keep looking but this is what i have located so far and it has been repeated on various sites:
FLYWHEEL/COIL AIR GAP:0.007 to 0.017 in
cheers
iai
May 04, 2011 | Poulan Garden
How can i convert the rope pulled generator into automatic start generator...
Yes you can install an electric starter on your generator if the following conditions are present. Starter/fan cover has cutout for starter, the flywheel has ring gear and block has taped holes to mount starter. Examine the engine where the starter would normally be installed (look at a generator like yours with the same motor that has the starter installed ) and check that the mounting holes are there and threaded to receive the bolts. If threaded holes to mount are there and access thru starter cover to flywheel is there, check that the flywheel has a ring gear where starter motor engages. If all present starter can be installed however you will not have the charging coil which is normally under the flywheel to charge battery; but you can still use the generator to charge the battery. To locate parts, use model number of the engine not the generator. Good Luck
Sep 30, 2010 | Coleman Powermate Generator Start &...
Colmen 6250generator
Yes you can install an electric starter on your generator if the following conditions are present. Examine the engine where the starter would normally be installed (look at a generator like yours with the same motor that has the starter installed ) and check that the mounting holes are there and threaded to receive the bolts. If threaded holes to mount are there and access thru starter cover to flywheel is there, check that the flywheel has a ring gear where starter motor engages. If all present starter can be installed however you will not have the charging coil which is normally under the flywheel to charge battery; but you can still use the generator to charge the battery. If you have more quesions about this please email, Good Luck
Jan 28, 2009 | Coleman Powermate Premium Plus 6250W...
Generator will not generate electricity.
I assume it is a hand start genset. The most common problem if it has been sat for a while is rust on the ignition timing flywheel. If you take the pullcord housing off (recoil) then you will see a big flywheel with what can only be described as a big forked prong with a couple of wires on it. This flywheel should be stainless steel and rusts when sat around for a while without use. Its job is to complete the circuit to the spark plug every time the flywheel passes the forked prong at a given spot on the flywheel, the faster the wheel turns the faster the spark hence the engine runs quicker. Clean the rust off with a releasing agent (wd 40) hey presto!!!!!!!!!!!
Sep 17, 2008 | McCulloch 13HP 338 Cc Portable Generator #...
Electrical Supplies Logo
29 people viewed this question
Top Electrical Supplies Experts
Gene Haynes
john h
Are you an Electrical Supply Expert? Answer questions, earn points and help others
