Question about The Office Equipment & Supplies
How do I replace the stripper pad on RISO RZ590UI.
Trouble keeping pads on my Koblenz floor polisher while stripping wax. Seems to glide at first then friction gets to strong for the pad . I tied more liquid but didn't seem to help. Thank you
You didn't strip enough wax with your mop, and now the old wax is plugging your floor polisher pad. Then the old wax starts to stick back to the floor. Flip the pad over and use the fresh side until it starts to stick too. Then soak the stripper pad in a mild soap solution and rinse it out thoroughly. After it dries, it should perform correctly. This is why you need several pads.
Dec 29, 2017 | Koblenz Tools & Hardware - Others
Replacing power supply in a Cuisinart CWC 1600 cooler
Remove the back panel, take out the internal power supply and replace it with another compatible AC 120v to 12v DC 5amp power supply. Often laptop power adapters will work. I used this one: 60w-12v-5A-AC-DC-Power-Adapter from the website mini-box. The peltier pad draws upwards of 5amps, but the rest of the system is super lower power. his power supply replacement takes about 20 minutes. You need: Philips screw driver, wire cutter and stripper, two 16 gauge wire nuts. That's it.
Dec 01, 2017 | Furniture
How do i change the color of riso drUm from red to burgundy?
How-to: Convert Z-type Color Drums ' stencil.wiki
stencil.wiki/how-convert-z-type-color-drums Procedure for converting the color of a Z-type drum. Steps 1 - 9 also work ... Z-type Color Drums. Posted: 17 Oct 2014 14:04 by issuepress Last edit: 01 May 2015 14:20 by issuepress ... This tells the Riso to recognize newly installed ink tube.
Riso RP3505 drum color change - CopyTechNet.com
www.copytechnet.com > Forum > Technical Forums > Digital Duplicators Sep 9, 2008 - 3 posts - ‎3 authors Is there any way to change an RP color drum to black? How to change a drum color on a Riso MZ 770E? (I'm new ... 3 posts 8 Apr 2014 Riso gr3750 Drum versus GR377\GR373 Drums. 6 posts 1 Jul 2013 Riso RP3700 Print drums wont ink up 7 posts 28 Sep 2012 Riso GR 3750 alignment, drum and colour change ... 9 posts 3 Oct 2009 More results from www.copytechnet.com
change color drum riso Questions & Answers - Fixya
www.fixya.com > Forum > Tags Find solutions to your change color drum riso question. Get free help, tips & support from top experts on change color drum riso related issues.
Risograph GR drum conversion.mp4 - YouTube
z? 0:25 https://www.youtube.com/watch?v=YCttIfFdu0Q Jun 30, 2012 - Uploaded by SpareResidency Used citrus solvent to clean the exterior of an old red drum then switched the ink for a new tube of blue.
My Top 7 Risograph Lessons - Alfalfa Studio
alfalfastudio.com/my-top-7-risograph-lessons/ Jun 16, 2014 - When you need to add another color, you open up the drum door and change the drum to use purple, for example. The Risograph prints one ...
Replacing The Print Drum (cylinder) (color Change ...
www.manualslib.com > ... > Printer > RZ1090 > User manual Riso RZ1090, RZ1070 Manual Online: Replacing The Print Drum (cylinder) (color Change), Replacing The Print Drum (cylinder) (color Change), Removing The ...
Riso printing - Instructables
www.instructables.com/id/Riso-printing/ Risograph The underlying technology is very similar to a mimeograph. ... This master is then wrapped around a drum and ink is forced through the ... Change the color drum, change the paper on the glass sheet, make a master layer and . ... Remember that every different color you want to print, you have to print separate.
Jan 31, 2016 | Office Equipment & Supplies
We have a gr 3750 and when the paper tray comes up the feed wheels do not start up to feed the paper in.Any suggestions
  1. check the upward sensor for adjustments and the sensor on the stripper pad unit for adjustments
Mar 13, 2011 | Riso Office Equipment & Supplies
Riso ? One Stripe in the middle.
Yes you are right. The 'stripper finger' is not lifted enough so it scratches the master.
I know this problem from a GR. But the procedure should be nearly the same for your machine. Behind the back cover you will find a small rubber roller. Diameter 12mm (1/2") or so. This roller runs at the excentic curve of the drum. You might find that the rubber is worn of and so the finger cannot be lifted enough any more. You have to replace it.
(Hint: For a fast momentarily solution you may fix it by several windings of adhesive tape.)
May 04, 2010 | Riso RZ390 Duplicator
The document feeder of our won't grab the paper
Check first the rollers and stripper pad if they are very sticky, just replace those roller. If not you can dismantle the covers on the feeders.find a solenoid and check the spring that attach on it. If the spring is broken replace it or just make a loop from the spring and reintall it from the solenoid. Then try to feed paper.
Nov 11, 2009 | Riso RZ220 Duplicator
Paper Jams
clean with a soft cloth and alcool the Paper Sensors, specialy the paper sensor (one under the drum), and also the clean the stripper pad, Pickup roller, Scraper roller, Gide roller, Timing roller in the firts paper feed drive mechanism
If you need the manual instructions post a mail at: Salasidis@sch.gr
Feb 25, 2009 | Riso RZ220 Duplicator
Feeding error
need to clean or change the tires that pick up and seperate hte paper in the paper tray
Sep 23, 2008 | Riso RZ220 Duplicator
Riso
probably needs a new adf stripper pad.. the first little rubber pad on the bottem of the inside of the adf
Aug 11, 2008 | Riso RZ220 Duplicator
Icemaker Ice Stripper Arm
just get a new im son quit n riggin the thing
Jun 15, 2008 | Whirlpool GD5SHAX Side by Side...
21 people viewed this question
Top The Office Equipment & Supplies Experts
Thomas F. Schneider
Keith Love
James Cagle
James Cagle
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
