Question about Frigidaire Refrigerators
SOURCE: frigidaire gallery pro series model frs26zsh water
Mor than likely you have a clogged defrost drain. Drain is located at the bottom of freezer compartment behind the back panel. You will have to remove the panel and blow out (or vacuum) the drain hole. Hope this helps
Posted on Jul 31, 2009
SOURCE: my frigidaire gallery FRS26ZSH refrige side is not
How to check
everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
The fridge gets its cold air from the freezer through a vent(damper)
between the freezer and fridge.The fan in the freezer blows air through
it. There is a flap you adjust with the
fridge temp. control. Make sure it's opening and closing when you adjust the
fridge temp.
If the evaporator coils behind the back panel of the freezer
are icing up because of auto defrost failure that will stop the circulation of
cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In
most newer models the timer has been replaced by an electronic control board.
If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks
and everything shuts down. The heater should now come on. If it does, replace
the timer. If it doesn't, check the heater and defrost thermostat. Turn the
timer again till everything starts back up to end the defrost cycle.
Posted on Sep 15, 2009
SOURCE: I have a Frigidaire Model FRS26ZSH need water filter instruction
Filter Status Press and Hold five seconds to reset
light. (This light will tell you when to replace the
water filter.)
press the button to the right of water filter to release filter...
Posted on Sep 19, 2009
SOURCE: frigidaire gallery model # GLG0642AS4 won't
If you have a gas dryer...
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Apr 15, 2010
SOURCE: 9-10 year old Frigidaire Gallery FRS26ZSH
might be your compressor relay gone bad. if the condenser fan was running and no compressor that could be the case. Also could be a bad compressor. you could try installing a 3in1 start kit. cost about $30. if doesn't start with that then compressor is kaput.
Posted on Jun 27, 2010
Jul 07, 2012 | Frigidaire Dryers
Mar 18, 2012 | Frigidaire Refrigerators
Jun 27, 2010 | Frigidaire Gallery Series GLHS269ZDB 36"...
Apr 21, 2010 | Frigidaire FRS26ZSG
Jan 20, 2010 | Frigidaire FRS3R5EMB Side by Side...
Sep 17, 2009 | Refrigerators
Jul 31, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Jul 15, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Aug 31, 2008 | Frigidaire FRS26R4A Side by Side...
Jun 12, 2008 | Frigidaire FRS-26DR7D Side by Side...
Oct 24, 2019 | Frigidaire Refrigerators
