Question about RCA Televison & Video
2012 RCA will not turn on with remote or manual switch without unplugging and replugging power cord a few times. Works great once on.
    Top Expert:
  • RCA Master
  • 66,248 Answers
SOMETHING RINGS A BELL ABOUT A LATCHING RELAY GO SEE A REPAIR SHOP WITH IT
Posted on Nov 08, 2019
6ya staff
SOURCE:
Anonymous
SOURCE: Westinghouse LVM-37w1 LCD HD Monitor
weird, my post disappeared. did any of you guys find a solution to the problem(s)? i too have no video, my volume buttons on the unit does not work though there is sound coming out the speakers, and my remote does not work. i had since upgraded/replaced the unit. it's sitting in my living room now. DaDakota, i wouldn't mind getting some money for it if you want to purchase it still. let me know. thanks.
Posted on Sep 07, 2007
mjap
Mark Payas
  • 107 Answers
SOURCE: RCA F27227EM 27''
maybe an IC is mulfunctioning around the power suply. a four leg IC, sometimes its white or gray, try to change it.
Posted on Jan 19, 2008
Anonymous
SOURCE: RCA 27' tru flat sdtv- power light comes on- no display,no sound.
How do you unlock your TV from Protective Mode? There is a certain code that you need in order to unlock the Television. The technicians are saying that it went into Protective Mode, when it umplugged all by itself. I need the code so I can watch my TV again.
Posted on Nov 24, 2008
Anonymous
SOURCE: "Turn Power Off then on Again" error
This solution worked for my OfficeJet L7680--good luck!
1: Disconnect the Universal Serial Bus (USB) or ethernet cable from the back of the product, but leave the product turned on.
2. Open the cover of the product and remove the print cartridges.
3. Close the cover and wait for the Insert Ink Cartridges message to display.
4. Disconnect the power cord from the back of the product and wait for one minute.
5. Reconnect the power cord. If the product does not automatically turn on, press the Power button.
6. Open the cover and reinsert the print cartridges.
7. Close the cover. If prompted, print a calibration page.
8. Reconnect the USB or ethernet cable, and try to print a print job from the computer.
Posted on Jul 07, 2009
SOURCE: On my Zenith Plasma model #Z42PX2D, when we turn
This is a common problem on these plasma TV's. The problem resides inthe high voltage boards known as the X and Y Sustain boards.. You canpurchase them here for a very reasonable price:
http://www.discount-merchant.com/Y-SUSTAIN-FOR-42-PLASMA-TV-PN-6871QYH036A-p/sku9510.htm
The above link is to a Y-SUS board. The X-Sus board is often the 2nd cause of failure and can be found here:
http://www.discount-merchant.com/X-SUSTAIN-6871QZH041B-6870QZE017D-6871QZH052D-p/sku9509.htm
Totest which board is failing, you need to check voltage input to theYSUS board first... Input should be 120V from Power supply, outputshould be above 250V.. Do this test with XSUS disconnected. IF 250+Vexists, then XSUS is damaged. If not, then the YSUS is the faulty part.
Posted on Oct 16, 2009
My RCA keeps quitting on me.
U have a part in there that is changing value as it is used or gets hot.
Look for a bad capacitor in the power supply - when that goes bad everything shuts down.
Also check the plug going into the wall for a sound connection with the wall receptacle.
Aug 06, 2015 | RCA Audio Players & Recorders
RCA F19421 Stuck on video since switched from dishnetwork to cable
Some RCA TV's have a "video" option that requires you to use the original remote control to cycle up or down the channels.
Also, try unplugging the TV's from the power receptacle for 30 minutes....some times, that will cause the TV to reset.
With the power cord unplugged, manually push the power button on the front of the TV to discharge all capacitors.
Ensure the 30 minute is complete before plugging it back in.
Let me know if this works.
Thank you!
Jan 02, 2014 | RCA F19421 19" TV
The power light does NOT go off and the TV will not turn on. I know the TV works because every once in a while I will plug it in and hit the switch and it turns on. I tried programing a remote and then...
As far i can tell,u said the tv u unpluging,repluging the tv back awhile later the tv will function and work is that correct?Yes,this problems,alway related to the tv power supply board,that the board where the tv power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.U said u tried programing the remote,is the remote u have and using is a universal remote,u don't have the tv original remote?Yes,try website like Remotes.com to buy the tv original remote too.
Jun 20, 2011 | Akai LCT2060 Television
I have no power to my Hitachi TV. It is plugged
try turning off main switch and unplug set then replug in wait 30 sec turn on main power and repeat then try if it works great if not power supply bad. i also suggest a ups universal power supply newer tvs sensitive to surges and brownouts also never turn tv off n on in short period of time will cause surge that trips protection circuit
Dec 29, 2009 | Hitachi 42HDS69 42 in. Plasma Television
65 inch rca scenium will not turn on, what steps should i take or try to get it to turn on. Please help i know nothing about tvs
Your power supply is most likely faulty. Very common especially in newer tv's. I would call around and get quotes from a few different people first. Unless you want to order a service manual and try to test for the faulty capacitor or resistor in the power supply and replace it yourself.
Sep 09, 2009 | Televison & Video
Is not turn it on again when i press manually, not from remote control, on control parent
Try unplugging and replugging,then reprograming the remote. Also try removing the batteries from the remote, holding a button down to drain the power, reinstalling the batteries, and reprogramming the remote.
Aug 11, 2009 | RCA 32V550T 32" TV
RCA F27227EM 27''
Jan 19, 2008 | RCA F27442 27" TV
Televison & Video Logo
29 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
