Question about Electrolux Washing Machines
My Electrolux EDH3586GDW dryer isn't doing a full cycle. I accidentally set a program no idea what or how & have tried resetting it by unplugging it for a bit but that hasn rectified the problem
I turn it on & the start/pause button is flashing, I press it & it goes for a bit then stops..with the same button flashing. Clothes are still wet & it's a small load & filter is clean. I need to reset it.
6ya staff
SOURCE:
Paulo
  • 188 Answers
SOURCE: clean light flashes
You will have to reset the console. To do this, close the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
Posted on Feb 20, 2009
Anonymous
SOURCE: pau err
I have had that problem before...Try unplugging it and plugging it back in...sometimes it's almost like dealing with a computer.
Posted on Apr 25, 2009
Anonymous
SOURCE: ''clean'' light flashing (whirlpool Dishwasher GU2300XTLS1 model)
I had the same problem recently and a repair person came to my home to fix the dishwasher. He said he had to reset the control panel. He did this simply by making sure the soap dispenser door inside the washer was closed, then making sure the main dishwasher door was closed and locked. Then he quickly pushed the Heated Dry button and the Hight Temp wash button alternately. He said each button needed to be pushed twice within five seconds. After he did this all the lights on the control panel came on, then turned themselves off before the washer went in to a test cycle. This simple reset fixed the whole problem. Works great so far.
Posted on Jun 16, 2009
beltronic205
Gerry Harvey
  • 1481 Answers
SOURCE: unable to use ZJ1217, start/pause flashing
Are you able to open the door ?if so door interlock switch could be at fault
Posted on Oct 02, 2009
Testimonial: "this is very helpful, Allthough I am not capable of carrying out this work I do at least know what the repair guy may say. thanks."
Anonymous
SOURCE: Dryer not working, indicates "lint
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Posted on Oct 09, 2009
Electrolux 517 dryer wont start.
open the door,look around the opening where you put the clothes in and send the full model number so someone can help you
Nov 10, 2017 | Electrolux Washing Machines
My front load dryer is displaying all 8's and all lights are blinking what does this mean
Good Morning Friend,
I understand your Electrolux dryer, model# EIED55H, is displaying all 8's and all the lights are blinking. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best regards-
WP
Jun 25, 2014 | Electrolux EIED55H Dryer
How to clear code on electrolux dryer
Good Afternoon Friend,
I understand you are trying to clear a code on your Electrolux dryer. I suggest resetting your appliance, be either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 23, 2014 | Electrolux EIED55H Dryer
What is an e64 error code on electrolux dryer ewmed70jss?
I understand you are receiving an E64 code on your Electrolux dryer, model# EWMED70JSS, and want to know what it means. What this is stating is that there could be a possible issue either with the heating element or some wiring. It could also be a possible false error code. I suggest resetting your dryer, by either unplugging it or shutting the power of at your home's circuit breaker, for 3-5 minutes. Restore power and try any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 16, 2014 | Electrolux Dryers
Electrolux dryer error code e62
I understand you are receiving an E62 error code on your Electrolux dryer, model# EIED55H. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jun 11, 2014 | Electrolux EIED55H Dryer
Whirlpool adp 4404 5 - how to do a RESET?
It is probably stuck in the dry cycle.
Press and hold the start button to clear it.
You should hear it pump put while it resets from memory.
May 27, 2014 | Dishwashers
Countdown timer not working
I understand that the timer on your Electrolux dryer, model#EIMED55IIW, is not advancing to show you how much time is left on the dry cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your homes circuit breaker, for 3-5 minutes. Restore power and restart your dryer. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your dryer status has changed successfully.
-Best Regards-
WP
May 18, 2014 | Electrolux EIMED55IIW 8-0 cu- ft- Electric...
Electrolux cde7700lw0 dryer
Good Afternoon Brain, this is Z. I am happy to assist you!
I understand that your Electrolux dryer (CDE7700LW0) door indicates it is open and your dryer will not operate. Let's try resetting your dryer by either unplugging it or flipping the household circuit breaker off. It is best to wait approximately ten minutes and then turn on your dryer. Select a normal cycle and verify if the dryer will start. If your appliance will not operate then it possibly have a faulty door lock assembly or a communication problem with the control board. In this regard, I would suggest contacting an Authorized Service Technician that will be able to assist you in the diagnosis of your appliance.
Apr 10, 2014 | Electrolux EIED55I Dryer
Electrolux dryer EIED55HIWO
Hello - Typically 88:88 on an Electrolux dryer indicates a generic power failure code. Try resetting the unit by unplugging it or flipping the household breaker off. Wait approximately ten minutes.
Dec 10, 2012 | Electrolux Dryers
Washing Machines Logo
Top Electrolux Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Poppa Maddo
Poppa Maddo
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
